You're sooo selfish thomas :spank:
I spotted a few lines today!! most memorable was a white r34 this morning ;) the guys said he was from this forum, but i can't remember his nick!!! but :wavey: and i wasn't stalking you!!! lol!!! skyline ass just makes for very good scenary! ;)
also spotted a silver r33 on castle hill road at about 8:30... hehe... i got a grin, and a finger shake?!!? :)
hey moanie ^^ , white car today was me
very clean r33
hmm. maybe i should get a more meaningful nick name lols
edit: whilst i'm here, also saw the following.
black r34 with for sale in liquid paper in the back windscreen @ george street whilst i was doing happy laps last night
red r34 at county drive Cherrybrook last night
grey r34 at the roundabout cnr county drive and boundry this morning
yellow r34 today turning into market city car park
ECL!!!! hahahaha... now i remember it!!! i have the worst memory in the world!!! :spank:
Congrats on the 34!!!! You said you'd only had it for 2 weeks? hehe... bet you still can't get over it!!! bring it out to the next cruise!!!! ;)
as for clean 33?? hahahaha... my car is the dirtiest you'll find around!! :uh-huh:
hahahaha, yer roughly 2 weeks give or take
still trying to work out using the tip
a must do is the next cruise for me =)
very clean r33
hi, would of replied earlier but wasnt able to post. all fixed now christian fixed it.
what time were u driving by on george st & whereabouts?
i was there waiting for a nightride bus between 1.30-3.00 roughly my watch is broken and lost my phone some ****s got it now.
neways
i saw like 20 odd skylines and rexs between milsons point and railway square. also saw the odd 350z roadster s15,rx7,supra,intergra and so on
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
