SPOTTED:
11:30 penno rd white r34 gtt,
6:15 marsden rd black r32 gtr
6:50 bexley rd, one of the meanest R34 GTR's ive ever seen on the rd!!!
was red with full kit (Cwest or bomex i think) large rear wing
wheels looked like that shadow gold color, and the car sounded soooo mean.
SPOTTED:
silver I think I know OF the car your talking about...dont know the owner...
did it have a carbon bonnet ?? and a red/white number plate ?
front bar is cwest and has an awesome carbon rear wing that I wanna get...hehe but not too sure about the rest..
its not a GTR....its got a GTR badge though....
Brad, you do realise that these cars are driving on public streets. Therefore, anyone who 'spots' them will be able to tell what their plates are and what bodykit is on it - including any potential thief. I know that I personally recognize cars by their plates. Also, most of the cruise pics have number plates exposed anyway for all to see.
:werd: i would have issues if someone said they saw a car parked in a driveway all the time.. but noone says that.. its road spots, where the car is MOVING! its not like a theif can head to where a sky was spotted to steal a car :( the car is not likely to be there!
haahahaha on the way to the SAU dinner at Indian there, you should have dropped in biatch.
but I don't have a tree fiddy zed....I had to borrow Kel's one :cheers:
Yes, well I would have attended the dinner, however the Overtime beast reared it's head and compelled my to stay at work.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
