hey R34NOS, I think I saw you up at palm beach a few weeks ago with an R32 GTS-T...
the other day I spotted a nice R34 GT-T, white, gold nissan badge on the front down the bottom of the front bar (on the lip) in avalon... was parked next to a Grey WRX Club Spec Evo 3
anybody on here?
EDIT:
also the other week I saw a silver R33 GTS-T Series II getting raped by cops at long reef, saw the cops looking in the car and shit, and the driver looking pretty pissed off... :) was that anyone on here?
Yeah the R32 GTS-T stopped to tell me he's got 500Hp on wheels and he wanted to race me on the road...But my girl was gettin pissed off coz she wanted to spend some time wit me....but it was a nice R32 though..the guy put a RB25 engine in it....looked nice too...
But we stopped on a very lonely road...How did you spot me there with him?? Were you in your car??
Seen a few lines around lately.
Firstly followed a beautiful black R34 GTR 'MADGTR' from Lane Cove to North Ryde last week.
Then yesterday had a clean white R33 GTR pull up next to me on the corner of Herring (I think?) and Epping Rd, opposite the Ranch. Gave eachother an acknowledging nod, and I proceeded to drool at his ROH rims and other aesthetical mods (subtle but very slick!)
That would be paul , bloody awesome car !
http://www.skylinesaustralia.com/forums/sh...ighlight=MADGTR
i saw this yesturday morning
suprised you didnt c me, im always there at that time
I think i saw you today on James Ruse Drive...silver R32 with sticker on the door ..couldn't get number plate ....I was in my lancer and i was gettin l8 for work coz i was in my lancer not skyline ;-)... Also i see every day R32 GTR dark grey driven by a old guy on king georges rd..
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
