spotted white r34 GT-R on anzac bridge
gave a friendly nod
very nice
That was me , i honked you when i went past you the first time , my gtr pearl white M-spec. Nice white 34 you got there it sounded like an auto .
Spotted XTATIK yellow pearl R32 GTR on Hume Hwy Cabramatta at 1:30pm, then a few seconds later a red R32 GTR GTR00F parked on a side street, and literally 3 seconds later, a silver? R33 with SLYR33 plates and carbon bonnet driving on the same street.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
