Damn so many dumb people who chose tele. :cheers:
I swear tele/elec eng is one of the top 10 hardest courses. It's not worth how much effort has to go into study because finding a job in tele (unless you have a near D average) is so bloody hard.
Damn so many dumb people who chose tele. :D
yep thats so true!!!!.... I was doing it then im out.. Failed so many subjects, Got friends who are still doing it now.. they are supposed to finish this year (4year at uni). But probably have 2more years to go.
spotted a grey/black 32 on kissing pt rd heading towards parra at about 12:30am-ish.. also spotted a greenish olive 33 with some weird style body kit turning onto marsden rd a few mins later...
and i spotted you on james ruse i was next to you in the bogan mobile HQ holden:wassup:
saw that VY malloo jump up ur ass pretty quick too
was that at the lights near the bp on james ruse?!?!?!?!?!?! hahahaha.. was that you?! why didn't you beep!!! i was half hoping you'd give me a run, but you didn't do anything... then the mallo was on my butt! lol!!! i wasn't going to speed.. and he backed off pretty quick! ;)
i'm in a very weird boosty mood these days :
yep BP lights
i only realised it was you after you took off
LMAO the bogan mobile run your car your jk arent you
its a 5L and it still doesnt move i cant wait to get rid of it and get back into my car
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
