suspension is gone ...my mechanic (the blue R34 GTR V Spec in the show IS666) reckons i've to get new again and its gonna cost me 5K again for HKS one...when i drive it drives ok but if i hit the back swings a lot now :-(( ....it doesn't feel like the car is gripping the road...
^^ as I said in the "getting to show and shine" - could have been possible car jacking..
didn't see any skylines today while I was down @ Royal National Park.. :) everyone was @ the SNS.. had some good fun punting around the windy roads though..
i spotted a shit slow ass s13 on the way back on the old pacific...going so slow we drive behind him for a while and decide to over take...
man man i granny is born every f**cken day..heheheh
maybe i friend was speeding abit..but i was soo bugger to speed..it was a long day..i was keep to the limit or abit over it and that it..there was so much tracfic on the freeway so we decide to take the old pacific, there were so many motor bike going really fast in the old pac...at lease 4 of them over took us..
and i dont think my friend was try to impress that gal..he didnt want her in his car...
I was in the 180 :P
he lost enough points to lose his license but the cops had no proof coz the radar didn't lock on and save it...he gets his full license in september anyway...mintie was behind us and he was going to pull over too and the cops told him to piss off lol...by the way i'm not from campbelltown :)
