Sure that wasnt NUR-66R?
I saw this one yesterday afternoon parked in its usual spot on the main road in Newtown
Beautiful car that one.
It may have been NUR-66R, it had blue slimline plates, in anycase a beautiful car.
Edited by Adam_54
JET#$R  coming back from old pac on sunday arvo
sorry dude I forgot your name!! My fault! :D:D:D
Your car looked and sounded very nice mate - awesome ride!
Cheers,
Chris
YiPPY..i spotted you too..glad to see a skyline flash me to greet me
Haha...nah just me coming out of a daze....(early morning)....
Thanks....
Your car looked nice...very very clean....
is that a 400r front bar?! hehe.. i don't usually like that bar, but it looks hot!!!!
thanks dude!!! hahaha... yeah.. nice and stock looking :P
Yeah, its the 400R bar....
I think its coz of the colour...
the colour attracts alot of attention though...(unwanted).
Someone tried to break into it last night....
My brother saw a Silvia S13 pull into my driveway last night at about 1am with its lights off....
My bro turned on his lights and they shit and got out of there.....
VERYY PAARRRANNOIIIDDD NOWWWWWWWW
yeah.. i was going to say the colour is half the appeal!!! :P i wouldn't have spotted you at all if i didn't see the splash of yellow amoungst all the traffic!!! hehehe... then it was excitement plus when i saw it was a sky!!!
ouch!! time to lock her away in a garage!!!! did your bro get the plates on the s13?
been seeing a few R31's near HITMAN(workshop) in penrith.
think i seen BWA thismorning wallgrove & GRT WSTN HWY lights,you was waiting for your lights to change,i was heading towards penrith.
about 5:30pm seen a chick driving a black 32gtst,at St Marys,turning right onto the highway into st marys,umm also a silver 33gtst MZQ-11k set of lights out front on Minchinbury,then a mum in a white 33gtst,then seen another 33 near the shell select at Eastern creek. all in a day.
oh and i been seing this white pulsar sedan 90 model(i think)
with fmic & looks like 4door 32 rear lights,looks good (Y)
Edited by RSTME
yay I have only had the car a month and this is 5th time I was spotted :(:):D
I saw you on the great western actually but didn't know who it was what speed were you doing? lol
Oh and every day I see the same white R34 on wallgrove road in the morning
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
