me??
I vaguely remember a white line somewhere along there..just can't remember which day!
yup pritty sure it was u, unless some1 stole ur car and had a face mask on that looked like u :D it was a tuesday around 6:30pm
On my way back from PIZZA saw Thomas's black 34 with.....
wait for it...
NO IMPULS! :P
Also 4loorit was out there happy lapping.
hahaha what tha ??
where were you marsss ????
I dont recall seeing your car ?
I saw SLY-33T or is it SLY-33R ? in the tunnel just before the tollgates on the M2
Edited by shonen
hahaha what tha ??
i went past yr car when it was parked on York St.
Nice new wheels by the way
spotted a lot of skylines yesterday, yet received no skyline love.
2 black r33's on the cumberland highway, and others..
1 of the black 33's was auto and very loud. Tried waving, no response, looked at him, no response... He kept on doing drive-by's past me till I got pissed off and floored it past his open drivers side window with the gate wide open....
He didn't come near me again. :lol:
ooh, also spotted my car in the latest HPI mag (with the new GTR on the front) crashing a 300zx dyno day at UAS.
:lol: I didn't even know about it till one of the guys at my mechanic's mentioned that he saw my car in a magazine.
I saw that i was gonna tell you. is than when you were at unique for the dyno day, and theres a guy talking to you while youre in the car with amanda???
Yeah man :D that's the one.
The guy talking to me is John (owner of UAS), he was asking me what I was doing there.. lol
lol, was going to tell you about a week ago, but never go around to it.
Spotted CYI(something), the white GTR with the black bonnet around the entrance of the M2 around seven hills.....my car broke down at the intersection :P....not a good day.
