Suki or whatever her name is from 2F2F is UGLY++
Havent you heard the saying "any holes a goal." :laugh:
Black. :huh:
Ill look out for your car...
I THINK I REMEBER YOU NOW! I was in the car with my sister maybe about a month ago..
you were driving next to me on bunnergong rd and down wentworth.. ave and then some other noodle in a skyline zoom past and you sped up with him.. maybe it was you.. theres not alot of of black 33's round the area..
I drive a black 32
Havent you heard the saying "any holes a goal." :huh:
I drive a black 32
dunno cant say I remember what happened last nite let alone last month. :laugh:
I forgot the password to my work email :P and only changed it last nite
OK should stop wh0ring in the spotted thread.. seeya!
omg :P with a name like corinne, i thought you were a girl?! :P
omg :) with a name like corinne, i thought you were a girl?! :O
HAHA :laugh:
If that was true
QUOTE(D_I_F @ 2 Mar 2006, 12:58 PM)
yea it is.. shes hot isnt she..
Very nice arse..
You know what the above statment would mean! :huh:
Double post moanie?
Is that a gremlin again or do you need to complain to prank!
i need to complain!! every thread i post (bar the whore thread) it gives me an error but posts.. so i refresh and it posts again!!!
Yes, sure its not a pebcak or an ID-10-T error?
JK :laugh:
Saw it happen in the NSW dyno day topic
sh ms!!!
spotted the below on tuesday evening:
spotted a white 33 on the city westlink about 7pm.. got a wave:D
also spotted another white 33 going the other way on the rd on the other side of parra rd from the city westlink! lol!!! he was heading towards the city.. i think i got a belated beep? :P
(posted it in the wrong spotted thread! LOL!)
Spot a Yellow R34 GTT every morning on the way to work on Lane Cove road heading towards homebush
Spotted a grey 32 GTR on pacific hwy chatswood heading northbound. Threw a wave...got one back
Spoted a silver 350Z taking my car space this morning at Chatswood.
oh! and corinne! check out the chick drag thread in the events section!! DO IT!!!!
i havent been able to post for ages now..
i dont think i would go in one of those.. :S
my cars mostly stock.. i dont have a cams licence.. i would have to do some work on my car before anything like that happened.. i dont even know what speed im going at my speedo is out.. :S
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
