Suki or whatever her name is from 2F2F is UGLY++
Havent you heard the saying "any holes a goal." :laugh:
Black. :huh:
Ill look out for your car...
I THINK I REMEBER YOU NOW! I was in the car with my sister maybe about a month ago..
you were driving next to me on bunnergong rd and down wentworth.. ave and then some other noodle in a skyline zoom past and you sped up with him.. maybe it was you.. theres not alot of of black 33's round the area..
I drive a black 32
Havent you heard the saying "any holes a goal." :huh:
I drive a black 32
dunno cant say I remember what happened last nite let alone last month. :laugh:
I forgot the password to my work email :P and only changed it last nite
OK should stop wh0ring in the spotted thread.. seeya!
omg :P with a name like corinne, i thought you were a girl?! :P
omg :) with a name like corinne, i thought you were a girl?! :O
HAHA :laugh:
If that was true
QUOTE(D_I_F @ 2 Mar 2006, 12:58 PM)
yea it is.. shes hot isnt she..
Very nice arse..
You know what the above statment would mean! :huh:
Double post moanie?
Is that a gremlin again or do you need to complain to prank!
i need to complain!! every thread i post (bar the whore thread) it gives me an error but posts.. so i refresh and it posts again!!!
Yes, sure its not a pebcak or an ID-10-T error?
JK :laugh:
Saw it happen in the NSW dyno day topic
sh ms!!!
spotted the below on tuesday evening:
spotted a white 33 on the city westlink about 7pm.. got a wave:D
also spotted another white 33 going the other way on the rd on the other side of parra rd from the city westlink! lol!!! he was heading towards the city.. i think i got a belated beep? :P
(posted it in the wrong spotted thread! LOL!)
Spot a Yellow R34 GTT every morning on the way to work on Lane Cove road heading towards homebush
Spotted a grey 32 GTR on pacific hwy chatswood heading northbound. Threw a wave...got one back
Spoted a silver 350Z taking my car space this morning at Chatswood.
oh! and corinne! check out the chick drag thread in the events section!! DO IT!!!!
i havent been able to post for ages now..
i dont think i would go in one of those.. :S
my cars mostly stock.. i dont have a cams licence.. i would have to do some work on my car before anything like that happened.. i dont even know what speed im going at my speedo is out.. :S
