Spotted the r34 GTR with the mines sticker on the side today... mmm looks niiice. Chatswood.
Sometime last week my gf saw ZER454 whale SAU sticker at uni. I also spotted CM... 34 silver at the gym. ARJ... white 34 stealth looking at forestway also.
spotted john "silvergtst" at DCMs last night... was an awesome night... nice to finally meet j00 :P
lol at ur message quote: "Msg me when you in. see rb20 always first" lol smart ass
yeh was a heaps good night, nice to meet you to peter andre
lol
spotted ANXIUS r33 gtr, on oxford st, blowing a bit of smoke on idle....
Spotted a very very nice gunmetal grey R32 GTR HKS*** on numberplates and autostyle sticker on the back, anyone on here?
a few other skys in the city last few days...
FARK that's not good news... close to home too! What colour was it? And more importantly was it anyone from here?
Sounds like someone failed to stop at the lights or the two imports were playing cat and mouse!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
