Spotted the r34 GTR with the mines sticker on the side today... mmm looks niiice. Chatswood.
Sometime last week my gf saw ZER454 whale SAU sticker at uni. I also spotted CM... 34 silver at the gym. ARJ... white 34 stealth looking at forestway also.
spotted john "silvergtst" at DCMs last night... was an awesome night... nice to finally meet j00 :P
lol at ur message quote: "Msg me when you in. see rb20 always first" lol smart ass
yeh was a heaps good night, nice to meet you to peter andre
lol
spotted ANXIUS r33 gtr, on oxford st, blowing a bit of smoke on idle....
Spotted a very very nice gunmetal grey R32 GTR HKS*** on numberplates and autostyle sticker on the back, anyone on here?
a few other skys in the city last few days...
FARK that's not good news... close to home too! What colour was it? And more importantly was it anyone from here?
Sounds like someone failed to stop at the lights or the two imports were playing cat and mouse!
