rukus i always see ur car dropping off a chick who i think goes 2 mclaey college is that u?
yes thats him and that chick is me! i work in that building! sif go to that college! :ermm: and that was a while ago :D when ms worked up the road and his car was on the road :D i miss my gtr taxi :D
ye twas mona
that was ages ago now.
my car = dead atm
hehehe yep i agree with TRUBLSM i went round a roundabout also car was in 3rd at 2000rpm and i went sideways round it lol wasnt even accelerating... and no i have ok'ish tyres... dunlop 2000 SP's
