Spotted the MARSSS mobile on ryde bridge the other night and also massiv on same brigde boosting it last night!, hey guys i'm the one working on the brigde at night, going past again give us a honk.
Hahaha! were you the guy with the paddle??? i was doing 60 and i got a dirty look... soi slowed down to 55... :)
haha nah i ain't no traffic controller, i actually work for a living. i was pulling making a hole in the road where all the trucks were parked, its funny cause my mate asks how can i tell when a skyline goes past cause everytime one does i look i said you can hear them coming.
BTW nice ride too MARSSS
Thanx champ!!!
Spotted white R32 GTR (AUN80S) yesterday - followed it down the F3, onto Wyong Rd across Tuggerah..... very nice!
Go the coasties!!! :D
hi tinks
spotted you back, v neat white 33 gtst, if you waved i carnt see nething through those side tints
go the white skylines!!! ;D
adam!!! where is ryde bridge and how long you there for?!?! *tries to plan driveby* ;)
skyline thrash ryde bridge tonight :)
Spotted a grey 33 near chatty thisavo, got a dirty look from the old fella driving it
spotted a 4 door 33 in roseberry (fark they look ugly)
White R33 gtst today that looked almost like Masses car except with stockies, had the stealth wing and all.
We were both on Kent st and he was in front and he gave me the thumbs up as I went pass...anyways I flashed my hazards as I drove past !
Anyways nice clean 33 !!!!
adam!!! where is ryde bridge and how long you there for?!?! *tries to plan driveby* :dry:
Gidday Mona, hows the car going?
Be there till end of next week probably, yeah that would be a sight to see all the SAU regulars doin a drive by!!
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
