Saw about 4 Skylines tonight in penrith.
1 Black R32 in the plaza parked up near the movies.
1 White R33 at Krispy Kreme carpark.
1 White R33 GTR at Krispy Kreme carpark.
1 White R33 turning onto high st.
I had number plates but after seenin all 4 i forgot them!
spotted a grey R32GTR with the plates RB-30-TT at Tempe Tyres a short time ago.
spotted a white R33S2 plates RB-33-GT driving through homebush - flashed and got a flash back :P
hey mate that was me...
i also spotted a black 32 GTR plates "HKS-27L" in botany nice ride mate!!!!
spotted this morning on the spit bridge. a black what i think may have been genuine r33 gtr 400r with the plates 400R. it looked genuine to me and sounded really tough.
Black or purple?
Spotted Thomas (shonen) last night hanging out at maccas with his possie ;)
Spotted Ranicx this morning making fun of a fulleh sick mirage >_< Who was a tool by the way
haha, yeh, the muffler on that thing was so huge! and lowered.. did it have dinner plate chromies as well? cant remember.
oh also spoted mona waving like a crazy lady out the passanger window too :)
Ohh and i've spotted a blue 34 gtr i think number plates STV 99* , a couple of times now, anyone???
finally spotted!!! that would be me dropping the GF home...
was telling her that u roadworks guys must be thinking what the hell is up with that car driving by at 1am every night of the past week haha
it's a GTT, btw
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
