Spotted "spooled" on lady game drive this arvo. He seemed distracted
lol so that was you
I was on the phone, heard you beep and before I could turn my head you were gone. :P
spotted ranix cuising with his chickie on penno rd.. then castle hill rd.. then new line rd... i was stalking you.... :rant:
i had no idea that you were following me! what car were you driving?
Spotted ranicx on Epping Rd this morning :(
Also spotted a black R34 GTT with red plates turning off Epping Road onto Lane Cove Road
haha yep spotted you too
Spotted a silver R33 S2 on Victoria Rd this morning.. BD-2990.. You were behind me..
I was in the *cough* red starlet *cough*...
its a courtesy car.... no really IT IS!! :)
I see you've upgraded! :D
you suck.
:D
Enough said :P
now what have you got for me mr? :P
hahaha. .i even messaged you! :D
i was in my parents commo! dad was driving and he refused to flash his lights, beep or charge up behind you :D
I see you've upgraded! :(
I have! It's a little monster!
No aircon, No power steer (to save weight and room in the engine bay), 1.3L N/A AUTO
0-100 in 5.2 (minutes)
Wakefield - 1.04 (hours)
And you've been getting yourself in shape, so your able to tame the beast.
Spotted ya playing squash on wednesday night at Dural courts.... Picked up a mate from there and saw the car.
Saw the Knock off Mines tuned R34 cruising around the city yesterday.. sounds like a beast.
Which garage did that car again? It was at Autosalon from memory.
Autostyle
Autostyle
It was actually not them, they just sold it
Ill let mr 32 explain this one, he knows the blokes that did it
But i can say when i first got a dyno power run done for my car, it was sitting right next to mine - in quite a few pieces :dry:
That's me, James.
Where did u spot me and why didn't I spot you...
Oh didnt know you had new plates
umm this was possibly on Epping Road - you would've been heading toward city way as you were going opposite direction to me,
If the plate is GTR**8 i saw it in pyrmont today... sounds mean.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
