Spotted: white 33 GT-R on Mowbray Rd in Artarmon at Midnight just gone. Whole bunch of SAU NSW members surrounding the car and drooling after the Great Northern Hotel closed and we had nothing better to do :laugh:
Spotted: white 33 GT-R on Mowbray Rd in Artarmon at Midnight just gone. Whole bunch of SAU NSW members surrounding the car and drooling after the Great Northern Hotel closed and we had nothing better to do :P
you left out the bit about someone humping the back of the car while it was waiting at the lights...!!! Dunno who it was but loved the look on the faces of the other drivers behind - hahahahahahaha!!!
spotted a bright purple 34 GTR yesterday on the F3 exit at Gosford... nice power play imports sticker on the rear window..... absolutly beautiful car !!! :P
Was it like a harlequin colour with Gold wheels on it?
Yeah, a brillant purple in the sun...I'm pretty sure it had gold wheels too. Pulled over on the side of the road with 3 other cars, an Audi & others. I drove past with the thumbs up, but the driver was busy. Hot ride !!!
spotted a do luck r33 GTR, midnight purple 33GTR, yellow vspec r34 GTR, lotus elise, holden statesman and a heap of BMWs and my car on the Bathurst to wisemans cruise yesterday. You guys should of been there, great pace and variety!!
spotted alot of lines last night the only one i can remeber was a whit 32 with black bonnet at thornleigh maccas number plate was oska or something.
Yeah plate would have been Osaka... Seen him around a few times. he's been on some SAU cruises too.
yeah thats the plate. the car sound a little rough but mabye thats cos of his running gear or somthing
Spotted a custom purple 32 with an absolutely gorgeous girl driving it at the 7 11 in Mt Druitt today, are you on here at all? thats an awesome paintjob you have their.
Also spotted a gunmetal 32 dumped on stockies in Mt Druitt that looked basically identical to mine.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
