saw this 32 Jeet on New Canterbury road this arvo
and then spotted Jess in her 'SINISTER' white GT-R about 90 seconds later turning off Crystal street
I have seen that silver R32 a few times, dont think he is on here tho
Huh where were you?
looks like someone may have bought one of the 34 GT-Rs at E&M. saw this guy test driving it at Five Dock
Still in Five Dock, saw this cbr250 that had met with an old Merc- nobody from here i hopes
saw this at Parramatta
nothing to do with 'Lines- just thought it was an odd car to have 'killa' number plates :(
congrats to babak, his cars a machine
i should have brought down one of our customers R33 GTR
would have given him a nice run for his money :domokun:
Cheers Anthony,
Wat GTR? wat Race 4 money? no no. me no race on the road,, u know... lol
Only at the strip with slicks and all that...
Hows evrything btw? long time no see...
Take care...
Babak
hey babak
the GTR is a customers car which just got back on the road today, apparently made decent numbers in japan gotta put in on the dyno soon and check it out
no racing on the road bro i meant it could have given you a run on the dyno at the dyno day :domokun:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
