Spotted that black R34 GTt with the two thick white stripes down the centre of the car today - not a fan, but I did notice that it had R33 GTR wheels, they suit it nicely!
Spotted a convertible S15 today!
was on the m4, saw a white car with silvia taillights but an unusual silhouette, as I got closer I realised it was a convertible. Looked kinda stupid, the shape was all funny :domokun:
Ah yes, the Varietta... N/A SR20
heaviest/slowest poser POS around
I see...
at first glance I thought... here we go another honda/mitsu driver who did a nissan conversion abomination...
but no it appears Nissan did that one all on their own... :laughing-smiley-014:
I see...
Autech did it... close :D
Spotted possibly DRDOOF coming off the F3 at Wahroonga around 11:20 or so lastnight?
And spotted a R33 GTST heading on the F3 at the same time..
Yeah that woulda been me :)
I was extremely tired, so you could have been in a 35 GT-R and I wouldn't have seen you :D
Doof, Sam (WTF-33R) and myself where all traveling down the F3 on Thursday night, and we all happen to drive R33 GTS-ts... well, maybe not Sam, his one be a four door.
If this other R33 GTS-t has a lightish red (AKA pink) boot garnish it could have been me :D
Spotted a few tonight, one white R33 with green Ps and a veilside rear bar, together with a midnight purple R33, both with GTR wings on George St Town Hall, next time be patient and don't block the intersection :D
A silver R33 parked out front of the Pavillion Hotel
And then later on a Silver R33 pretty chunky bodykit including GTR wing, cruising through Hornsby towards Waitara at about 2am, I was the black R33 heading the other way.
spotted a bayside blue r34 GTR with blue HID;s i think on gilbert rd at about 12 midnight ...sounded nuts
maybe its the same Tommy Kiara one i always see around the hills area
No my brother was driving my car today but said he had it back home by 8pm!!
Maybe Possum! She lives in the area!
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
