Spotted a silver R33 this morning at about 9am on the Princes Highway in Tempe. Number plates were Ax-xx-xx I think?
Also spotted a silver R34 last week on King St in Mascot doing a reverse park into a spot across the road from the school there.
Yep. White n14 with a pushed in rear end hahah.
Today spotted a white R33 GTR near Chatswood.
Also spotted a blue R32 GTST or GTR parked at BP near the airport, big chrome impuls.. looked really clean from a distance.
That was me :-) Finally spotted!
Doof were you strolling around chatswood westfield carpark after work yesterday? Spotted a nice tidy white r33 rock up about 5:45 and then some well dressed bloke strolled past my r34 as i tried to run him down (not seriously) But hey could of been another bloke in the r33 heaps around these days
And Moei I was in KFC getting mad discounts for mums day, used to manage that kfc h
spotted Sn-33-ze
aka Andrew and stuck my finger up to get you back from last time ... but you didnt even see me :spank:
and there was a black 32 infront of you
spotted a black r33 on enterprise drive , tumbi umbi tonight at about 7pm.. got and gave a wave.member?
Hey i know its a bit late t i only just found this thread :spank:
Possible me as im always on enterprise drive around that time coming home from work..
i have a 400r front bar.
Spotted a white R33 this morning. It was parked behind the flats on the corner of Wentworth Ave and Botany Rd, Mascot. Rego was XPG-260, from memory.
Also spotted a black 32 leaving the Eastern Distributor last night about 6:15pm. You were in front in the traffic a bit, so didn't get a good look.
lol i swear i've seen you a while ago driving through chatswood...got a picture somewhere too :) Niice car mate.
Yeah I'm pretty sure I've seen you around chatswood too a few times... once while I was enjoying company at Big Fish Little Fish
thx mates, coz I live in chatswood :thumbsup:
make sure give me a wave or horn next time :)
Edited by spikey
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
