Then a white 33 with black rims on it (maybe Enkeis?) pulled into the carpark just after me at Pick N Payless in Blacktown.
That would be me :laugh: Rims are 5zigen. i seen you parked in the car park, noticed your plates all new and stuff :D nice and tidy 32 you have there.
Spotted yellow r33 with a flutter down canterbury road this afternoon near home hungry jacks.
As well as a midnight purple r33 gtr plates gtr330 gold plates to. In parking lot behind hungry jacks.
And a 4door r34 navy in colour. just down from the gtr.
that was me waiting for Albert. to go to e/c. plates are r33 gtr
i was the one leavin the grass parkin and u waved when u were goin in. silver 33 s2.
gotcha
gtrsean said it was driving behind us on way back from coodgee beach, maybe he was mistaken
haha..yeah
it wasn't me :(
spottted a white 34 at bankstown on hume hwy at the stacey st intersection. very clean, had sau sticker and a chick driving :(
That chick would of been Anna :)
Oh hai babe :(
also spotted kezillon skylines down eastern creek today
Yep spotted a million Skylines at EC yesterday. A few I recognised but they wouldn't have known me anyways ;)
Also saw Slim pulling out onto pennant hills road when i was driving back from EC.
That would be me :D Rims are 5zigen. i seen you parked in the car park, noticed your plates all new and stuff ;) nice and tidy 32 you have there.
Ah nice one! Your 33 looked nice man - shiny. :) Glad you didn't look inside my 32. It wasn't so nice and tidy in there! I'd driven it to Pick N Payless with the dash and centre console pulled apart and tools and shit all over the seats and floor. Luckily they had the bit I needed on an old Maxima. How'd you get on? Find what you needed? I love that place.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
