Spotted a silver R33 twice cruising along the Pacific Hwy between Mt Colah and Berowra, gave you a flash at Mt Colah lights but was in a blue subaru. Plates were HLDOON, car looked mean.
female owner
lives near my gf
not on here to my knowledge
a mate had it at his workshop and it was v. tidy
Saw 4 Skylines today within the space of about 20 minutes driving!
Two R33's - one black the other silver in the morning around Turramurra/Wahroonga area. Near Kintore Street
In the arvo; white R34 GTT around the same area as described - let off some loud revs as it went past
And a light blue R31 turning from the Pacific Highway onto Telegraph Road at Pymble. Red P-Plater
female owner
lives near my gf
COULD possibly be Loz... she mentioned she knew someone down this way...
girl on the left, car on the left... is it a SII? :D
spotted this laser driving around
had 19" TE37s
LOOKED GOOD!!!!
Haha. Wheels would be worth ten times more than the car if it were true! Nice rims.
Saw a shiny black R32 this morning turning off Copeland Rd at about 8:30am. Didn't get much of a look but it had no spoiler and looked clean. I like seeing other black 32s around. :)
female owner
lives near my gf
Wasn't Grim Performance was it?
Hey Doof, can't have been Loz mate, wrong plates. Series 1 silver R33, lowered heaps, probably a few other mods, very clean and agressive looking for a girl's car, I like!! :)
Spotted a random purple R33 GT-R with stock rims and a SAU sticker on the front bar on the way to Mount Kuring-Gai today. Even saw mr moo himself driving it. :banana:
spotted you as well at the last minute. gave a wave but didn't know if you saw me.
