Was just driving behind a black R32 GTS-t with GTR wing, lowered on stock wheels. HCR-23T plates. I followed you coming off the M5 and heading down the Princes Highway. I saw the SAU sticker on the back, but I was in that black Getz (company car) so it would've been a bit confusing had I waved.
spotted a few skylines over the weekend. spotted a midnight purple (i think) R33 GTR in penrith with plates R33 GTR.
That'd be Mitch (mr moo). Gold plates with black text? They're from South Australia, from memory - he's going to have to give them up eventually. :D
maybe...i thought they were black with silver/white text but i could be wrong...such a clean car wasn't taking too much notice of the plates lol
Mitch has already given up his old SA plates (which were from the previous owner), and now has regular NSW plates on the car - no special number sequence on them or anything...
Spotted a standard white V35 sedan at the end of my street, then another white V35 coupe with mags and a Bayside Blue R34 GTt on Old Northern Road in Castle Hill.
spotted a maroon R33 driving thru epping about 20mins ago... i was a couple of cars behind ya. Didn't catch the number plates but it was running ritch as i could smell ya from way back lol
Spotted a lovely Silver R32 GTR today along Mona Vale Road just before St Ives. Had an SAU sticker on the rear side window. Fairly dirty at the rear end of the car. Number plate was 'AQ 92 ZI'. The guy driving it was very conservative, good driving :O If he's online here I was in a white Peugeot 206 just near the petrol station at St Ives shops.
Peace
Thats was me :)
Was heading upto Newport Arms for lunch/dinner
Spotted a sliver 33 GTST with plates "SQ 11 SH" outside Epping hotel at like 1am yesterday/this morning
Seen it round there before, has SAU stickers on rear side windows
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
