Guest barbie iz a bitch
right you are mona! cuz mz barbie chick keeps raving on about what a cool place teletech is to hang out i decided to check it out for myself!!!!
simply just pointing out how many ppl suprisingly seem to hang out at my work!
its shit house!!! tay had a party last nite n so i'm very much feelin like rat s***!!!!!
Oh? u feel sh*t???? you went to bed early.. I feel like iv been hit by about 20 trucks and like i have drank a glass of poisen.. :throwup: I passed out around 6am after I finished those smirnoffs..I cant belive I have to go to work I feel like Im going to die.. :P
Yeah Ed? y didnt flik invite you! how rude!!! :jk: Fliky u know I luv ya chicken!
spotted Messiah! parked in Yale close in north rocks last night!! :P
hey crazy car crash on pennant hills road.. If anyone plans to drive down it today i advise you not... ( unless you feel like coming to my work to give me some sort of hangover-cure pills) At least I had an excuse to be late to work.
:jump:
u suck!!! that y u missed out. i'm talkin 2 hot aussies! green p's, blonde scruffy hair, almost as hot as macca's guy!
very much HEY HOW U DOIN?!?! nice wheels too...
LOL go flik. Just cos I was in training.. Ill go hunt them down..
p.s Im sure they dont beat the maccas guy :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
