Spotted DR4GON yesterday.. looks like you spent more on rims then anything else on the car :) I think she needs a wash :)
i saw this aswell this morning. those spinners are shocking!!!
also spotted a blondie chik with sum good potential driving a black r32 gtst.
pretty sure ive seen it parked on that road that goes from george st down to the fish markets, but this time saw it driving past tafe.
plates are yrm ?00 i think. car looks pretty stock, sounds like it has a pod filter.
if ur on here, u got great taste in cars!!!
(or is it ur bf's??) hahaha had to say it
Spotted at Dutton Rally
Black 31 with GTR engine and very loose left front control arms...doing big lockups and drifts all weekend
Black 32 gtst driving sensibly and doing well ;)
Blue 33 GTR doing 11.3 in the 400m test (and getting caught by the 31 in the EC circuit sprint rofl)
Red 34 GTR not blowing up this year and cleaning up Class A (skyline class :D )
and in the carpark a red 31 with an rb25, a black 31 with a new rb20 and a 31 with the trusty old rb30.
And a bunch of other stuff like lambos and porkers
and a bunch of loud drunken troublemakers going through numerous cases of beer at some motel in Goulburn.
i think it was yesterday in the morning, I saw a silver r33 gtst on Maxwell St. Its the second time ive seen this car.
plates : NIZOOM
blonde female driver.
I see her car allllll the time in West Ryde...
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
