Yea i think it had a series two wing
Anyways shortly after that i saw a white r33 gtst pass by, had a series two wing but it had no front bar on it and i didnt see an aftermarket fmic so i think it was stock except for the exhaust.
hehehe... yeap thats right!  he does work there :)  I hear he has bought alot of stuff off you! hehe... i'm just waiting to see it all on his car! :D
Oh!!  and sorry to hear about your baby :D  thats gotta suck :)
u serious? b4 Craved does anything 2 his car i think he should get rid of the black door...nice car but one black door looks sh!t with a blue line...
SPOTTED: dark blue line - ABS 527 i think those were the plates...cant remember now. in my brothers workshop! :)
Yes all true. The Ztt makes 330+rwkw with almost no lag:worship:.......no no bad, i'll win one that's what i'll do! lol ..anyway make sure you get Craved and urself down the Street meet if he isn't workin, we are running the 33 GTS4T. Should suprise A few GTST owners off the line..:burnout:
Hmm... i'm yet to see a ztt!!! Make yours the first! :)
When you running the gts4t?! 330rwkw? thanks for the tip!! i won't be taking you on in a hurry!!!! :D
Hmm... i'm yet to see a ztt!!! Make yours the first! :D
When you running the gts4t?!  330rwkw?  thanks for the tip!!  i won't be taking you on in a hurry!!!! :thumbsup:
It's always good to be different, was also thinking of a GTS4 32,0r 33 with a 2JZ
The 33GTS4T is running today/tonight.
A 2JZ engine? that sounds familiar.... what car does that engine usually sit in?!
hmmm.... taking a camera? i don't think i'll make it out there tonight :thumbsup: at least the weathers holding up! :D
Edit: SUPRA ENGINE????? Is that right? Or am i thinking down the wrong path again?!?! why are you doing an engine conversion like that?!?!
Damn straight you're rooting for the rb26!!!!!!!  or you're out! :thumbsup:
how is it stronger than the rb?  i always wanted the supra!  till it found out what a skyline was, that is! :D
not sure on the technical aspects...but all i know is that it can withstand a bit more power than the rb26....with stock internals...
haha who is going to kick me out ???
you ? :D :jk:
Hrmp!! who cares! its still in a supra! :D
but now that you've said that, that might explain why BOOSTD wants to put the engine into a GTS4!!! Cause you'd be able to pull more power before messing with the internals?
Hell yeah i'll kick you out!!!! I'll leave a foot imprint on your butt, and then own it for good measure! :thumbsup:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
