Yea i think it had a series two wing
Anyways shortly after that i saw a white r33 gtst pass by, had a series two wing but it had no front bar on it and i didnt see an aftermarket fmic so i think it was stock except for the exhaust.
hehehe... yeap thats right!  he does work there :)  I hear he has bought alot of stuff off you! hehe... i'm just waiting to see it all on his car! :D
Oh!!  and sorry to hear about your baby :D  thats gotta suck :)
u serious? b4 Craved does anything 2 his car i think he should get rid of the black door...nice car but one black door looks sh!t with a blue line...
SPOTTED: dark blue line - ABS 527 i think those were the plates...cant remember now. in my brothers workshop! :)
Yes all true. The Ztt makes 330+rwkw with almost no lag:worship:.......no no bad, i'll win one that's what i'll do! lol ..anyway make sure you get Craved and urself down the Street meet if he isn't workin, we are running the 33 GTS4T. Should suprise A few GTST owners off the line..:burnout:
Hmm... i'm yet to see a ztt!!! Make yours the first! :)
When you running the gts4t?! 330rwkw? thanks for the tip!! i won't be taking you on in a hurry!!!! :D
Hmm... i'm yet to see a ztt!!! Make yours the first! :D
When you running the gts4t?!  330rwkw?  thanks for the tip!!  i won't be taking you on in a hurry!!!! :thumbsup:
It's always good to be different, was also thinking of a GTS4 32,0r 33 with a 2JZ
The 33GTS4T is running today/tonight.
A 2JZ engine? that sounds familiar.... what car does that engine usually sit in?!
hmmm.... taking a camera? i don't think i'll make it out there tonight :thumbsup: at least the weathers holding up! :D
Edit: SUPRA ENGINE????? Is that right? Or am i thinking down the wrong path again?!?! why are you doing an engine conversion like that?!?!
Damn straight you're rooting for the rb26!!!!!!!  or you're out! :thumbsup:
how is it stronger than the rb?  i always wanted the supra!  till it found out what a skyline was, that is! :D
not sure on the technical aspects...but all i know is that it can withstand a bit more power than the rb26....with stock internals...
haha who is going to kick me out ???
you ? :D :jk:
Hrmp!! who cares! its still in a supra! :D
but now that you've said that, that might explain why BOOSTD wants to put the engine into a GTS4!!! Cause you'd be able to pull more power before messing with the internals?
Hell yeah i'll kick you out!!!! I'll leave a foot imprint on your butt, and then own it for good measure! :thumbsup:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
