Yea i think it had a series two wing
Anyways shortly after that i saw a white r33 gtst pass by, had a series two wing but it had no front bar on it and i didnt see an aftermarket fmic so i think it was stock except for the exhaust.
hehehe... yeap thats right!  he does work there :)  I hear he has bought alot of stuff off you! hehe... i'm just waiting to see it all on his car! :D
Oh!!  and sorry to hear about your baby :D  thats gotta suck :)
u serious? b4 Craved does anything 2 his car i think he should get rid of the black door...nice car but one black door looks sh!t with a blue line...
SPOTTED: dark blue line - ABS 527 i think those were the plates...cant remember now. in my brothers workshop! :)
Yes all true. The Ztt makes 330+rwkw with almost no lag:worship:.......no no bad, i'll win one that's what i'll do! lol ..anyway make sure you get Craved and urself down the Street meet if he isn't workin, we are running the 33 GTS4T. Should suprise A few GTST owners off the line..:burnout:
Hmm... i'm yet to see a ztt!!! Make yours the first! :)
When you running the gts4t?! 330rwkw? thanks for the tip!! i won't be taking you on in a hurry!!!! :D
Hmm... i'm yet to see a ztt!!! Make yours the first! :D
When you running the gts4t?!  330rwkw?  thanks for the tip!!  i won't be taking you on in a hurry!!!! :thumbsup:
It's always good to be different, was also thinking of a GTS4 32,0r 33 with a 2JZ
The 33GTS4T is running today/tonight.
A 2JZ engine? that sounds familiar.... what car does that engine usually sit in?!
hmmm.... taking a camera? i don't think i'll make it out there tonight :thumbsup: at least the weathers holding up! :D
Edit: SUPRA ENGINE????? Is that right? Or am i thinking down the wrong path again?!?! why are you doing an engine conversion like that?!?!
Damn straight you're rooting for the rb26!!!!!!!  or you're out! :thumbsup:
how is it stronger than the rb?  i always wanted the supra!  till it found out what a skyline was, that is! :D
not sure on the technical aspects...but all i know is that it can withstand a bit more power than the rb26....with stock internals...
haha who is going to kick me out ???
you ? :D :jk:
Hrmp!! who cares! its still in a supra! :D
but now that you've said that, that might explain why BOOSTD wants to put the engine into a GTS4!!! Cause you'd be able to pull more power before messing with the internals?
Hell yeah i'll kick you out!!!! I'll leave a foot imprint on your butt, and then own it for good measure! :thumbsup:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
