Yea i think it had a series two wing
Anyways shortly after that i saw a white r33 gtst pass by, had a series two wing but it had no front bar on it and i didnt see an aftermarket fmic so i think it was stock except for the exhaust.
hehehe... yeap thats right!  he does work there :)  I hear he has bought alot of stuff off you! hehe... i'm just waiting to see it all on his car! :D
Oh!!  and sorry to hear about your baby :D  thats gotta suck :)
u serious? b4 Craved does anything 2 his car i think he should get rid of the black door...nice car but one black door looks sh!t with a blue line...
SPOTTED: dark blue line - ABS 527 i think those were the plates...cant remember now. in my brothers workshop! :)
Yes all true. The Ztt makes 330+rwkw with almost no lag:worship:.......no no bad, i'll win one that's what i'll do! lol ..anyway make sure you get Craved and urself down the Street meet if he isn't workin, we are running the 33 GTS4T. Should suprise A few GTST owners off the line..:burnout:
Hmm... i'm yet to see a ztt!!! Make yours the first! :)
When you running the gts4t?! 330rwkw? thanks for the tip!! i won't be taking you on in a hurry!!!! :D
Hmm... i'm yet to see a ztt!!! Make yours the first! :D
When you running the gts4t?!  330rwkw?  thanks for the tip!!  i won't be taking you on in a hurry!!!! :thumbsup:
It's always good to be different, was also thinking of a GTS4 32,0r 33 with a 2JZ
The 33GTS4T is running today/tonight.
A 2JZ engine? that sounds familiar.... what car does that engine usually sit in?!
hmmm.... taking a camera? i don't think i'll make it out there tonight :thumbsup: at least the weathers holding up! :D
Edit: SUPRA ENGINE????? Is that right? Or am i thinking down the wrong path again?!?! why are you doing an engine conversion like that?!?!
Damn straight you're rooting for the rb26!!!!!!!  or you're out! :thumbsup:
how is it stronger than the rb?  i always wanted the supra!  till it found out what a skyline was, that is! :D
not sure on the technical aspects...but all i know is that it can withstand a bit more power than the rb26....with stock internals...
haha who is going to kick me out ???
you ? :D :jk:
Hrmp!! who cares! its still in a supra! :D
but now that you've said that, that might explain why BOOSTD wants to put the engine into a GTS4!!! Cause you'd be able to pull more power before messing with the internals?
Hell yeah i'll kick you out!!!! I'll leave a foot imprint on your butt, and then own it for good measure! :thumbsup:
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
