Hey guys,
The problem I am having is that i can not get my car to hold a consistent boost level. Boost will jump around between 10-14 PSI which is causing me major issues with what i assume is the ECU going into R&R mode from what I've gathered reading around here.
The previous owner has installed a 3 inch turbo back exhaust along with a FMIC, after which he said the boost level rose to 12 psi, which in reality can be anywhere from 10-14 psi.
This is how it is currently set up. Ignore the T-piece $30 boost controller, It was originally running straight hose in its place and it has had no effect on boost levels since adding it
The problem that this is causing is a major flat spot in the rev range between 3.5-5000 RPM. It basically kicks in boost hard at 2500RPM, feels like I'm only on 3/4 throttle for 3.5-5000RPM then kicks hard again to redline. From what I've read this seems like the engine is going into R&R mode as I'm maxing out the airflow meter at 14psi. I think i confirmed this when i reset the ECU, the car felt like it was on 3/4 throttle for the first 5 minutes, then after that I'm assuming as the ECU learned A/f ratios again it leaned out most of the rev range and the car felt the same again.
From reading around here, it has been suggested that the 3 inch exhaust is not causing enough back pressure for the waste-gate to function correctly because air is flowing too freely through the turbo and there is not enough pressure for the air to need to flow through the waste gate. The fix for this would be fitting a 2.5 inch muffler only to increase pressure throughout the rest of the system. Quoted at $380 but seems weird as most people would be running 3 inch exhausts and mufflers here.
Any ideas on whats causing the boost to jump around so much? This isnt spiking either, it'll jump to about 14psi and stay there.
Plugs are brand new coppers, the NGK ones with the recessed tip, gapped to 0.8. Coils have been siliconed to eliminate them but they looked alright and i couldnt see any arcing at night before i did them so im pretty sure they were ok. Cars only done 65,000km, Series 2
I'm only looking to run 10psi so i can avoid R&R issues.
Cheers
Edited by Sparky206
that exhust story is rubbish , you have a stock ecu i was getting the same thing it was hitting R and R it has nothing to do with the exhuast turning your boost controller all the way down should run it at 10 if it doesnt it could be a faulty controller or you have a intercooler leak somewhere so the boost is all over the place, is your turbo stock
The boost controller has no effect, when i got the car, it didn't even have a controller, that blue line was just T-peiced onto the black line and connected straight to the waste gate. Turbo is stock
Edited by Sparky206
Connect a hose from the metal pipe coming from the plenum straight to the actuator to eliminate and faulty controllers or solonoids and it should be fine. If not there is a problem elsewhere.
If you just have a vac hose running from the plenum/intake manifold directly to the wastegate actuator, and you block the hose that runs from the stock boost solenoid to the intake pipe the boost should be steady. If not, the wastegate actuator may be at fault. Pull it off (easy 2 bolts and a circlip) and use a bike pump with a gauge to test it.
Nah it wont be that...it will most likely be the actuator...its the only other thing.
Chuck another on or check that the rod is not seized and that the diaphram holds vacuum.
Well i had another go at it today with great results. Made up a restrictor plate with a 2 1/2 in hole in it and put it in where the muffler bolts up, plumbed boost lines straight into the waste-gate actuator and took it for a drive.
Boost sat solid at 7psi, previously setup like this it would be hitting 14 psi. Plumbed in the boost controller set to 10 psi, started at 10 psi, crept to 11 then dropped off to 9.5 towards the top of the rev range.
Very happy with results and i guess ill stick on a 2.5" muffler as a permanent fix
What you should do now, is take the plate out and try again.
Changing two thing isnt the best idea, its better to do one at a time.
But glad to hear its fixed! I would def try removing the plate 1st and leave everything how it is.
I have a 3" turbo back, the dump pipe is custom and is massive. No cat, and HKS cat back. There would be sweet FA backpressure there. I use an R32 10psi actuator and dont have problems. So i would guess that your exhaust isnt actually the issue.
Yeah i did one thing at a time, wouldnt go past 11 psi with the boost controller in at first and was dropping slightly at higher revs like most cars instead of going up like it was. Was a bit hard to tell if it was just the hot day here or the plate keeping the boost levels down so i removed the controller and just used wastegate to hold boost and it sat rock solid on 7, when in the same configuration it didnt before.
It was this thread that basically led me to trying the restrictor, and he had already replaced the wastegate
http://www.skylinesaustralia.com/forums/R3....html&st=60
It may just be a certain stage of mods that make this happen, combined with a certain dump pipe. Looking around i noticed it was common on supra's to need a restrictor plate aswell
I bet you have a split diaphram causing it not to open fully - usually becomes an issue at peak turbo efficency as the wastegate port needs to open the most at this point to maintain actuator pressure.
The idea of blocking the exh to fix another issue is just stupid.
could you expand a little more on the symptoms of a split diaphragm and a replacement part?
You most likely have a split diaphram within the actuator. Meaning that some air maybe bleeding away causing the wastegate not to open as much as it should. Get an upgrade actuator or one that isn't split you can test them by putting 20psi into them and listening for leaking air.
You do realise that with a 3" exh on a std R33 ECU running more than 10-11psi you will actually start loosing power - thats if the AFM is still in good condition.
Yes i realise that i'll start loosing power, im happy enough to run 10psi, not looking for anymore.
As for testing the accuator, what would i use to build up 20psi on it?
Tee you boost gauge in so you can watch the pressure than add a bike pump or air compressor with a blower nozzle if you have one and listen for leaks. If you dont hear any leaks by 20psi than its fine.
i put a rb25det in my non turbo r33, i dont have the gold thing with the vacuum tubes running to it.
can someone tell me what it is and what its on the car for?
Edited by Stealthynsa
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
