Hi.
You can do this yourself if you have a hacksaw.
Take the bolt to somebody that sells copper pipe.(Bunnings?) You want pipe that it inside diameter is 12mm- the outside of 14mm is ideal however if it is say 15mm all is not lost.
If 15mm cut the pipe along its length only 1 cut. Then cut to size required to fit in whatever it is tap in carefully( use a copper drift, rubber hammer or a soft piece of wood) .
As you tap in it closes up and becomes 14mm. Dont worry about it being copper as it is only a locating insert.
Hope this helps
  • 2 years later...
ok, i need some 14mm to 12mm sleeves - apart from spending a day walking around hardware stores trying to find somthing that will work is there anyone that makes these?
Pm Scotty nm35
He's done loads of them.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
