Hi.
You can do this yourself if you have a hacksaw.
Take the bolt to somebody that sells copper pipe.(Bunnings?) You want pipe that it inside diameter is 12mm- the outside of 14mm is ideal however if it is say 15mm all is not lost.
If 15mm cut the pipe along its length only 1 cut. Then cut to size required to fit in whatever it is tap in carefully( use a copper drift, rubber hammer or a soft piece of wood) .
As you tap in it closes up and becomes 14mm. Dont worry about it being copper as it is only a locating insert.
Hope this helps
  • 2 years later...
ok, i need some 14mm to 12mm sleeves - apart from spending a day walking around hardware stores trying to find somthing that will work is there anyone that makes these?
Pm Scotty nm35
He's done loads of them.
