Hey everyone, its been ages since I've been a part of the forums but I've recently bought my other half a Series 2 Stagea RS4 S manual. It's a great car defiantly what we were looking for after owning an R33 but now with family future in mind we needed something else without making much sacrifice.
The main issue which I'm having is with the factory fitted gauges, the only gauge that functions correctly is the voltage meter, the front torque meter is unresponsive and boost gauge only sits at 0 even under boost. The Turbo is defiantly boosting correctly there is no hesitation or leaking just no response from the gauge.
If anyone could point me in the right direction with where I should start looking it would be greatly appreciated, the needles on the gauges do operate as they do fall when the engine is off and will move when the ignition is on. The car is completely stock.
Thanks in advanced.
have you checked that the boost sender unit is connected to the intake plenum? With the ignition on the guage will read atmospheric pressure and go to 0 mmhg, if it isn't plumbed into the intake plenum with a pressure/vacuum hose then it will not see anything. If it has fallen off then you will also need to check that the intake plenum is not open to atmosphere. I should think the motor would run pretty rough if this is the case so I would think that the sender unit must be faulty
Hey guys, thanks for all you're advise its all come in handy and we've now fixed the issue. It came down to a simple split in the vacuum hose at the sensor end and also we cleaned up the contact terminals of the sensors as well, this fixed the issue right away.
Front torque gauge also works, it was more or less dormant as we haven't pushed the car in anyway but took the car out to the farm on the weekend and as soon as we hit dirt road sure enough the gauge kicked in.
It's amazing how a little back tracking through the sensors and hoses turns out something so small and yet enough to disable the gauge, we ended up finding another sensor way out of nowhere where the issue was with the hose, but funny to think out of the 3 or 4 sensors required to figure vacuum that unless all sensors are plumbed correctly theres zero response from the gauge.
Anyway thanks again problem solved :banana:
Anyway thanks again problem solved :D
i was the same with the torque guage until i read up on how the whole system works ;)
of course i had to test it too :P
yay for another RS4s :banana:
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
