Take this as an example
Nothing against DR Drift but:
Anyone interested? PM or E-Mail me.
Send me a message with your name, car, credentials (who knows you to vouch you're one of us not a bluey) and anything else may be interesting.
L8r all
DOC
Would he be concerned about a copper emailing him if they were talking about drifting at qld raceway or another nationwide track? If you're gonna set a standard, keep it!
and sorry to bring u into it dr drift
Mase - I haven't seen Dr Drifts thread - when I do, I'll edit that too.
Its ILLEGAL! And you are posting on a public forum owned by ME! Who do you think the coppers are going to contact if you guys are silly enough to do it on a public street and kill some poor sap who's driving home and they find out it was organised on this forum?
use your head man!
Christian
  • 3 weeks later...
There is a Drift day going on this sunday (1/2/04) at QLD raceway, I think its $65 to enter and $30 if you want a set of tyres oh and $60 for the CAMS licence I think.
$10 to spectate though for a whole day of driftin, cant beat that!
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
