Hi,
I've got an EP82 Toyota starlet. Like most imported cars, these things run rich straight out of factory. I recently wack a SS mainfold, SR20 turbo in it. Car runs beautiful on boost but off boost is an issue......
It runs way too rich off boost (from 2000rpm to 3500rpm) to a point where it created mis-fire sometime. I've checked everything, thermal switch works, watertemp sensor works, O2 sensor works, engine light don't come up, change sparkies, change igintion leads.......ect still won't fix the problem.
Long shot here on this forums but someone might have an answer,
Thanks
https://www.sau.com.au/forums/topic/292697-map-sensor-car-running-way-too-rich/
Get an aftermarket ECU and tune it properly? Of course its not going to run properly. It would be expecting the tiny turbo to be on boost much sooner so thats probably why its overfueling down low. Could be running lean on boost as well. Seriously get it tuned with a copgy back fuel controller or a full ecu asap before you break it.
Edited by Rolls
Thanks,
What i thought but i also thought that it should be able to sense boost pressure, when boost kick in and such but i guess not :P. SAFC it is.
Thanks,
What i thought but i also thought that it should be able to sense boost pressure, when boost kick in and such but i guess not :P . SAFC it is.
It will but who knows what the max level the stock map sensor can handle? Its probably reaching load points its not meant to and running wrong size injectors etc. I'd be betting the stock computer is just going wtf and not knowing what to do.
I had a Starlet once, and you do not need a remap, the map sensor reads until 1,25 bar. Stock injectors will make 200hp for sure.
Check your vaccum hoses, it is VERY possible tha this is the cause.
Just because it can sense that much doesn't mean it knows what to do with the values. How do we know what the manafactures had in mind when they programmed the computer? If it exceeds load cells and the max pressure it expects to run it could just dump fuel and retard timing all over the board for a preset amount of time. There's no way to know.
Yeah, i've been told about Vacum hoses, has done lots of checking but not on the dyno so can't really tell while its under pressure.
Turbo A and Turbo B can both be at the same boost pressure... The difference is, they're flowing different amounts of air.
This is why the tune is up the shit.
Go and get it tuned. Nothing else to be said.
Guys,
I did a stupid test :) , ran the car with the O2 sensor un-plug and guess what...........it ran faultlessly lol. Does that mean the O2 sensor shat itself?
Quite likely, I would still put it on a dyno, you don't want to pop your motor because its pinging/running lean/rich. Only cost you $50 or so.
Oh yeah i'm still going to run it on a dyno first just to be safe but i think at least i've got to the bottom of it.....phew.
Guys it was making problems OFF BOOST, there was no problem when on boost, nothing to do with tune when off boost. 4EFTE's are very rich from the factory they handle EXTREMELY well at 0.6 boost with OEM setup, Trust me i had one with 315hp and searched a lot.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
