I'm gathering information for my next series of upgrades.
I have a 95 R33 GTS-t. My list of mods includes
HKS pod filter
3 inch exhaust from turbo
Power FC
AVC-R
and a FMIC. = 192rwkw.
I would like to upgrade the turbo with the aim of approx 250rwkw.
My questions are about the support systems.
How much power will the standard clutch handle?
I plan on a new pump and injectors. I was thinking bosch 044 and sard 550's
Does anyone else have any suggetions. Has anyone used these injectors?
Value for money?
Do I need to get anything else apart from the injector and collar?
I dont plan on going internal in the engine at this stage but if I do I cant see me going over 300rwkw, would these injectors be ok.
The fuel system so far is the one thing that is causing me the most confusion so any help would be good.
https://www.sau.com.au/forums/topic/29276-upgrading-support-systems/
I have an almost exactly same setup and was looking to upgrade to 230 - 240 rwkw. I decided against it mainly for the cost, once you reach over 200rwkw parts start to get quite expensive.
What support systems you will need:
Z32 AFM
550cc high impedence side feed injectors
Min. heavy duty clutch, twin plate is better
Bosch 910, 040 fuel pump.
Comments:
. You will definately need the Z32 AFM, you will maxing out around 200-210rwkw on the standard.
. 550cc injectors is recommended, however some say using a rising rate regulator is acceptable on stock injectors up to 240rwkw. I prefer not risking it and getting the injectors done. Sard prices are good, but they do not come with the collar necessary for straint plug-in fit. I sourced HKS for 78k Yen.
. I was going to continue to use my heavy duty exedy clutch and see how it went. Without launching hard at every opportunity it should have been OK. It's more a matter of torque than anything anyway. Twin plate would give you no problems - but adds to the cost.
. I was planning on getting the 910 fuel pump because my target was 230-240rwkw, and like you don't plan on doing internals. Getting bigger pump is still OK.
Now that I have helped, can I ask what turbo you are looking to use for this?
Thanks for your help Torrens.
I havent chosen a turbo yet. I'll have to look into that later but I thought I better get the other stuff sorted first. I would prefer a turbo that would not be laggy. I am more interested in having good midrange rather than outright power at the top end. What turbo are you going to use?
as per my signature, the only upgrade to my fuel system was a bosch 910 fuel pump, stock injectors, stock fuel regulator. The injectors are at roughly 70% duty cycle. The trust td06 or a garrett gt30 is probably the go for your turbo upgrade.
Thanks rob. Are you still using your standard clutch?
No Rob's clutch isn't standard.
I also am using stock injectors and have over 300rwkw, but I use a Malpassi fuel reg.
WOW I didn't think that was possible. I have been told by my workshop that I'll need new injectors if I want to go over 220rwkw. If i can get away without getting new ones that would be good. Does anyone have any opinions good or bad on their aftermarket clutches?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
