Hey
Long story short I got a GReddy Copy forward facing plenum for basically nothing and am getting to the stage where I can put it on. Before anyone says anything im not putting it on for an extra 2000kw or anything, I just like the fact that it will clean up the engine bay and make a few things much easier to do. The plenum has been checked out and it looks all good.
Anyway.. Basically just after advice on a few things. I've looked through the thread about installing one and its pretty helpful.
- Cooler pipes - I have cheapish chinese cooler pipes that came with my cooler so I've decided I'm just gonna get new stainless ones made for it. I was going to run it through the hole where my current cooler pipe runs (sorta underneath the washer bottle on the side of the guard, the usual spot) but I think i might just run it straight through where the washer bottle currently is. Does anyone have any suggestions for this and if anyone is willing to tell me how much they paid for coole pipes to a FMIC then to the turbo with front facing plenum, keeping in mind i will have to have a pipe for the aac valve and BOV off the main cooler pipes.
- Washer Bottle - Ill be getting rid of my washer bottle for the cooler pipes probably (if i dont go through the current hole). Where is a good place to get a replacement with the two outlets for both washer motors? Have a mate with the same plenum and similar setup to what i want to run but he claims his washer bottle is out of a series 2 R33 (mine being a series 1) but Im not sure if thats where its from, his is mounted between the bumper and front part of chassis just before the radiator
- Just any other general advice or suggestions would be appreciated... I have a basic idea of costs and stuff and think I have thought of everything (have got plenty of boost line, got the kit with the plenum with all the adapters bolts etc and will be getting new intake manifold gaskets etc from nissan) so just any friendly advice that anyone has for me would be much appreciated
Thaks Guys
https://www.sau.com.au/forums/topic/293082-installing-front-facing-plenum-soon/
are you passionate about your car and parts you put on it??? if you are then done put the cheap crap on. i have been down that path and will never buy another shit part again....you will just do it twice...maybe even three...
either get agreddy one or a plazmaman one...simple. i put a plazma one on and its amazing. plus it actually fits!!!!
Hey
Thaks Guys
Hey dude,
I recently put on one of the vulture motorsport plenums. If you have done a bit of work on cars before you should have no big problems. It is a fiddly job, some of the bolts are in a f**ked spot and a few clips and stuff gave me a bit of curry but in the end it wasn't to bad.
I re-used the manifold gasket that came off the old plenum. Just put gasket goo on it and it's sweet as. Wouldn't hurt to fit a new gasket though.
With the plenum I have it has an adaptor to run the stock throttle body. I did this. With the adaptor the throttle body sits way forward, so I could only run a 90 degree silicone bend straight off the throttle body. I pulled the washer bottle out and cut a hole through where it used to sit. I wanted to keep the bottle in for legal reasons so I took it the the plastic welders. Got it cut in half, keeping the half that has the motors and got the side closed up. It now sits back in the stock position with hardly any f**king around
There are alot of dodgy cheap ones out there but some aren't to bad for the price. I paid $550? from memory and it came with a throttle body adaptor and everything you need to do the swap. Bolted on nicely and had no problems
Thanks for the tips guys.
The plenum itself is pretty good,its not a cheap ebay one, its from autobarn. And i know its still not genuine but ive had it checked by more then one person and the facing for the runners to bolt onto the head is nice and flat and the injector holes are nice and flat for a good seal. Ive seen alot worse anyway.... And the only reason im putting it on is basically i got it plus cash for the rims that came off my car. I want to neaten up the engine bay, not make 700hp so im not to concerned about performance gains
M3ld: Thanks for that pic mate thats pretty much exactally the setup I have ready with the stock TB adapter. Never though about geting the stock washer bottle altered but doesnt look to bad, Thanks mate
wlspn: Dont think we have Bursons around here.... never heard of it so not quite sure, might try repco or somewhere, but i think im only after one gasket so if i have to get it from nissan i dont mind forking out a couple of bucks.
PM-R33: Ive seen your setup around, its nice, Think steven has told me about your car once or twice to, Im quite a fan of it
So thanks guys, I've done a fair bit of work on cars so im not to bad with everything. Dad's decided he's going to buy a tig welder so between the two of us i think we are just going to make the cooler pipes here, save having to get it somewhere to get it done and should save a couple of bucks to
Any more tips, I'm more then happy to hear them
Thanks again
dont listen to some of the ppl who are saying stay away from cheaper products, they either havent even tried before or just going off wat other idiots say on here..
im running same plenum have now for 50,000kms 350rwhp 20psi daily.. never had a drama. so good luck with it..
yeh man, im not worried, got a mate with a 25 powered r32 with 300rwkw+ with the same plenum as mine. Any future plans of mine will be at the most jus touching that power, but probably a bit under. I Love genuine Greddys and pazmaman's, but Id probably have never got one. Was just lucky that this one kinda fell in my lap lol
i have tried and i am slowing getting rid of every cheap shit part on my car...
horses for courses i guess... i just dont want cheap shit anymore....you do things two too many times.
its all about personal standrads too...some people dont appreciate fine food...and well thats fine too. but i like quality...thats all.
best of luck with the plenum install...
u do know that the standard plenum can hold like a f**k load of power right???
i personally wouldnt buy cheap shit for my car i made the mistake once by buying a saber cooler kit and it was a big mistake
Easy to access spark plugs
dropped intake temps from 75degrees at TB to 35degrees at TB
shorter cooler piping.
from what i could tell if anything it gained a bit of lagg due to the plenum being bigger then stock.
over all looks 10x better then the horrible factory inlet manifold.
just say when i install one of these, what sort of intercooler would i need? like which type would i tell them? because the pipes come diffrent.. or would it have to be customed made?
yeh you have to get the pipe on the plenum side custom made.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
