New - so the following questions might be basic to most of you.
What is a RB26 N1 block? Where do you source them from? What do they cost? What is the difference in price to a standard RB26 block.
Reason - Want to prepare a block, so car is not off the road for long when I am ready to replace the bottom end (which according to everyone is only a matter of time, if I track the car (R32GTR) without oil supply upgrades).
Confused! So what $$ are involved to put together a strong bottom end, not over the top, just a reliable combo that can handle up to approx 350 - 380 RWKW:
Option 1
Build a standard RB26 = $
Option 2
Build up a N1 block (or can they be purchased as a complete "crate" bottom end from Japan?) = $
Option 3
Build a RB30 block (have a VL sitting in the shed - so free!) = $
Look forward to the replies/advise
Steve.
https://www.sau.com.au/forums/topic/293836-n1-block/
just jap http://justjap.com/store/product.php?produ...=334&page=1
THIS ENGINE IS NO LONGER AVAILABLE TO PURCHASE FROM NISSAN
- Brand New R33 GTR N1 Long Motor
- Fully Assembled
- All Components Brand new
- Ready to Install
- 500PS Package
Engine Package Includes:
- Front Differential
- Sump
- Tomei 1.2mm Metal Head Gasket
- Tomei Metal Intake Manifold Gaskets
- Tomei Metal Exhaust Manifold Gaskets
- Tomei Poncam Type B Camshafts (260 Deg/9.15mm)
- JJR Adjustable Cam Gears
- Sard 700cc Injectors
- Sard Dual Entry Fuel Rail
- HPI Stainless Dump Pipes
- SSI Premium Stainless Exhaust Manifolds
- HKS GT-SS Twin Turbo Kit
- Gates Strengthened Silicone Timing Belt
- Trust Clear Timing Belt Cover
- Nismo Engine Oil Cooler Sandwich Plate
- Nismo Engine Mounts
- JJR Direct Ignition Coil Packs
- NGK BCPR6EIX-11 Iridium Spark Plug Set
- N1 Oil Pump
- N1 Water Pump
- Cooling-Pro Silicone Water Hose Set
- Ceramic Coated Plenum
- R34 GTR NUR Coil Cover Emblem
- HKS Oil Cap
- New Genuine Nissan Air Regulator
Engine Internal Specifications:
Displacement: 2568cc
Bore: 86mm
Stroke: 73.7mm
Compression: 8.5:1
Block: N1
Pistons: N1
Conrods: N1
Details
SKU BUILTN1ENGINE-JJR
Quantity in stock 1 item(s) available
Price: AUD 23000.00
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-4904049
Really depends what parts you put into it
Any headwork? a built rb26 would be the cheapest be around the 8-10k mark
N1 is a 24U block which has higher nickel content i think....
http://justjap.com/store/product.php?produ...=1&featured
3k ontop of the rebuilt rb26
rb30 into a GTR would need an adapter plate
and some fabrication to the front pipe, shave off the twin turbo plate, and cutting the frame off the bonnet where the timing cover hits
Engineering and gaining a Mod approval with emmisions testing for this could get very very expensive
If you search the forced induction thread you will find this topic has been extensively covered
Best of luck mate !
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-4904077
There are things you can do to minimise the potential for a spun bearing, without taking the engine out for the more definitive upgrades. The basic approach is to overfill the engine oil by about 1litre and fit an oil catch can that drains back into the sump.
Once you commit to taking the engine out, then you can fit an extended sump with baffle kit, head drain (which also drains back to the sump) and an uprated oil pump (N1, Tomei, Jun, etc). You can do this without stripping the head off the engine. These all deal effectively with the problem of oil accumulation in the head causing starvation of the bottom end.
If you commit to stripping the engine down, you can also fit the 50 cent Tomei oil restrictor, which prevents the oil accumulation in the head in the first place.
So three levels of what you can do. Just don't assume it is going to fail and you need to build a spare! Spend your money wisely and you can minimise the probability of it happening!! If you are going to regularly track the car, you really need a sump extension and baffle kit, oil catch can plus oil pump upgrade anyway.
I have had the middle level done to my engine at Garage 101 and am very happy with it. My knowledge of these things is that of the enthusiastic amateur, so don't take my word for it. Speak to a few people, such as Danny at Garage 101, or Steve (who was looking at this thread - Hi, Steve!).
Cheers. :banana:
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-4904598
Best of luck mate !
8 k will do just the bottom end well thats what mine is costing @ garage 101
Edited by gazza750
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-4904641
RB30 is a better block.
:cool:
SPOOL ENGINE REBUILD KIT SUIT:
RB30DET, RB30ET, RB26DETT, RB25DET, RB20DET - $2450
Spool Forged H beam Conrods
CP Forged Pistons ( Rings, Pins and Locks Included )
Cometic MLS Headgasket
ACL Race Series Big End Bearings
ACL Race Series Main Bearings
http://www.spoolimports.com/content/SPOOLSPECIALS.asp
Then you still need stuff like oil pump and crank collar, head drain/vent, machining/balancing, sump baffles, adapter plate, then assembly.
Edited by bubba
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-4904757
  • 9 months later...
I believe they've stopped producing the N1 block also?
This would push the cost of them up significantly I would think. Correct me if I'm wrong :)
i work for nissan and prcied up a genuine N1 block the other day, figures where around the $4500 mark, and parts where available from melbourne :ermm:
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5401920
like above.
N1 block can still be bought brand new from Nissan.
They normally sell for around 150,000yen to 200,000 yen on yahoo auction. (BRAND NEW)
example:
http://page4.auctions.yahoo.co.jp/jp/auction/d108631287
However if your looking at a new block why not go the NISMO GT block (2.8L) set you back around 270,000yen brand new from nismo
edit: for the price just jap is selling the long motor n1 i would much rather a nismo long motor
http://page6.auctions.yahoo.co.jp/jp/auction/f87398055
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5401933
Th GT block as such is not a 2.8 litre. The GT engine the block was designed for was a 2.8 litre it has a crank with 4mm extra stroke (Same as the Tomei one but different to the HKS which is a full counter)
The GT Block differs from the N1 in that it has thicker walls in some critical areas.
The N1 has 24U stamped on it.
The GT has RRR-45 stamped on them.
Nissan only ade 200 GT blocks in total ad they are all sold out, they now sell for Y600,000 in Japan from private owners.
Also there are two versions of the N1, the older one has much less Nickel content and is not as strong, you can tell the difference by looking around the water jackets near the top of the cylinder.
I have a new N1 block waiting an engine build up, and I know a guy who has some GT blocks that he would sell.
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5401986
NISMO GT block (about 2weeks ago) sold for around 280,000yen on yahoo auction so 600,000yen is abit over the top
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5402008
No it isn't.
Just because one particular block went cheaply, for whatever reason, that doesn't reset the pricing benchmark.
Nismo GT Block's aren't made any more so they are fetching huge money overseas, and ~600,000yen is around the norm.
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5403416
Nissan still sells the blocks, just not the assembled N1 long engines ;)
They sell N1 blocks - yes, but the GT is not available, if someone an prove hey are and show me where I ill buy one.
Y600,000 on Yahoo is the asking price, I have never sen one sell for Y280,000, please provide a link to the auction.
If someone is after the ultimate engine, there was a HKS HIdeck block for sale recently (with step3 crank, pistons and rods), only 20 ever made. This is the same block as HKS and heat treatments use for their drag engines, these are the fastest skylines in the world.
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5410459
Here is a link to a photo of a Hi-deck engine that endless-r destroyed
http://endless-r-tuning.blogspot.com/2008_12_07_archive.html
The conrod is really long so that under extreme boost and power levels it is less deflected andless likely to puch itself outside the vblock.
The spacer plate on top is water cooled and the block is cement filled. The spacer plate does the job of getting all the heat out of the upper area of the piston. (very little heat travels down the skirt compared to the top anyway) Lower heat can bve dealt with by more oil capacity and a large oil cooler. With this setup can run all day long n the dyno
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5410531
http://www.draganddrift.com/photos_img.php?img=393
A better pic
https://www.sau.com.au/forums/topic/293836-n1-block/#findComment-5410556
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
