  • Replies 61
^^ Brids, he already has a FMIC and turbo back exhaust. :)
Boost controller is the next step then maybe a tune, get an APEXi Power FC...
Upgrade your Panel Air Filter to a high flow one, like APEXi, K&N just to name a few... Or you got an air pod?
I never new the Crossfires where that fast...
mate i got a HKS pod filter, seriously bro dont know anything about crossfires its just one of my
friends he has an r34 and his girlfriend just bought a crossfire he drove it and said they are good.
thats y i was a bit concerned.Getting a manual boost control next week, Powers FC is next on the list
its just ma pocket is holding me back this month, was looking for a second hand over here but can seem to find 1 for a good price
still searching
powerfc, injectors, gt35 internal gate, exhaust manifold spacer, z32 afm, 22psi boost.
gogogoog
why just beat him when you can completely annihilate him
Agreed.Thats what am gona do still have time ill put all the godies in my line and then take him to Calder
What he just mentioned is about 5 GRAND or more worth of gear.... not to mention clutch and tyres etcc...
u'd be getting close to $10,000 ...
so at the end of the day...is it worth it?
just asking(and assuming)...do u have a small package or something and need to show ur a man?
u've got the basic stuff... buy a $50 manual boost controller and get some more boost... if he wins hes no better or worse a bloke then you...
just remember that when your laptop says "danger to manifold"
SLAM it shut and tell it to shut up!
you'll run 10's
srsly tho.... crossfires are slow as... a 33 with basic mods will munch it
thats not a thing mate i respect all racers its just if some challenges you u cant step back :thumbsup:.
i boutght the car 2 months back i got it for just one reason ill maki it a fast gtst.cant do it all at once but the guy challeged me at the wron time but still have to keep
upto mark :)
Rent my car for the race. Its being Scoutered to have a power level of over 9000!!!!
Also comes with a different buttons for different stages of turbo boost transformation to boost the power further from 9,000+ to 12,000 to 18,000 to 21,000 to 24,000+
Crossfire have a 0 to 100 time of ~8 or something?
Edited by Mayuri Krab
you'll run 10's
ur right bro its just didnt wana munth it want to swallow it :).so have to do a bit uv mods. :thumbsup:
You are correct my brother man. It is just that I did not want to simply masticate said crossfire, but digest it entirely. I do believe I will require modifications to my automobile.
huh?
:thumbsup:
Check this out. It will give u ideas
(POSITIVE)
0 to 100 6.5sec
It can reach 150+ MILE flat. 250kph
Check this one out (NEGATIVE)
Top gear
Well i reckon u can beat it if u know how to launch it!
Edited by tavstar34
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
