It has been brought to my attention that whoring is getting out of hand again.
It has caused acouple of businesses to discontinue using the boards, which doesn't bode well for when we approach these places for sponsership in the near future. It is also attributing to the slow speeds some dial-up user have been complaining about.
so please keep to the topic and only whore in the whore thread.
I will be cracking down on it till the new year. Threads that are closed will not be re-instated.
https://www.sau.com.au/forums/topic/29456-whoring/
instead of wasting a whole thread and annoying the people that are ACTUALLY talking seriously in it, why dont you post a warning first, telling certain people to stop whoring. If they continue you can ban them for a day or week ... or u can close the thread if you have warned people and they have continued.
I know this msg in itself is a warning to the users on the board, BUT, i still think it would be more fair for the people talking seriously if the persons whoring were pointed out, and asked to cease doing so. that way the more serious conversations can continue.
Ive seen many topics go to waste because they are closed because of some twit that spams random crap and the rest suffer from it.
https://www.sau.com.au/forums/topic/29456-whoring/#findComment-602826
This "whoring" is getting sh*t outta hand ever since a few key members joined.
How about this....
*NO WHORETOWN
*NO WHORING IN THREADS
*ALL OFF TOPIC POSTS TAKEN TO THE GENERAL WASTELAND.
That people can't take it to PMing/ICQ/MSN or even IRC, hell, even requiring a whoretown is beyond me.
https://www.sau.com.au/forums/topic/29456-whoring/#findComment-603526
they tried that - but as you know TJ most of us dont like mIRC.
Sounds like a politician ...."Lets shut down the only avenue people have for whoring to stop whoring" :confused: "Say wha?"
A lot of friendships have been formed in that thread and i think it would be a mistake to shut it myself. I think people that are whoring in the inappopriate threads should be sent a warning ...... when i first joined SAU i didnt know what Whoretown was used for i just thought it was you guys being dirty buggers. :D
https://www.sau.com.au/forums/topic/29456-whoring/#findComment-607164
yeah because WA has so many other resourceful threads at the moment :rolleyes: ..... :) and the quality justs going to go ...up, up, up when you shut down whoretown .... the first thing we do when someone opens up a shitty trivial thread like some we've seen in the past is tell them to discuss it in whoretown first instead of starting up a thread for it. Soon as you shut down Whoretown your going to have all these shitty little "tufa" like threads again. Whoretown isnt even used as much as it used to be ..... in fact its probably used 1/3 not even that as much as it used to be used so i dont know where the bandwidth issue comes in.
https://www.sau.com.au/forums/topic/29456-whoring/#findComment-610227
i agree, the forums have gone downhill rapidly in the last year. whoretown is a waste of time and resources, and the cause of many frustrating "the server is too busy" messages when you try and look up something useful. maybe if people developed a certain level of social skill we wouldnt need internet threads in order for you to 'make friends'.
https://www.sau.com.au/forums/topic/29456-whoring/#findComment-611010
i agree, the forums have gone downhill rapidly in the last year. whoretown is a waste of time and resources, and the cause of many frustrating "the server is too busy" messages when you try and look up something useful. maybe if people developed a certain level of social skills we wouldnt need internet threads in order for you to 'make friends'.
lol but true
there are no more useful threads becoz you can find the answers to everything on the search button
https://www.sau.com.au/forums/topic/29456-whoring/#findComment-611092
How about a Poll of the general population of SAU to vote whoretown out/mIRC plugin in?
Democracy is always good, and would prevent "committee members" just deciding that they like whoretown, so everyone has to put up with it.
There is a General Conversation forum where everyone can whore as much as they like. Let's keep it semi-tidy.
I can almost bet money on the fact that each state having thier own whoretown contributed to the "Server Busy" errors we recently had, and forced the upgrade of the server.
This is an online community, not a chit-chat/dating agency.
https://www.sau.com.au/forums/topic/29456-whoring/#findComment-611399
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
