Hey all.
Today I went to Winton for the second time with my S14. It has R33 GTS-T brakes all round with stock rotors and QFM A1RM pads all round.
The last time I came and for the first two sessions today the brakes were great however around half way through the day my pedal started going soft and then began to studder. I came into the pits and had a look at the front discs. They were dark and had heaps of pad material spread over them. The near new (at the start of the day) front QFM pads were now down to indicators. The backs however were fine.
Now it looks to me that I've gotten these things way too hot. I was doing a warmup lap, 2-3 hot laps, then a cool down lap, then another flyer then retuning to the pits with another cooldown lap. Is this too much for a pad like this to handle?
Looking around various forums these seem to be advertised for basic track work. Should I be warming them up or cooling them down differently? My car is lighter than an R33 so someone running them on an R33 would have bigger issues I'd imagine.
For the record the splash guards have been removed however I have not made any custom ducting yet. (Apart from the stock air guides on the caster rods) There are also no shims/backing plates/etc on the pads and I'm running Motul RBF600.
https://www.sau.com.au/forums/topic/294727-overheating-pads-qfm-a1rm/
I had same problem, new A1RM's up front lasted 80mins with the big UAS GTR brake air deflectors: (more details: http://www.skylinesaustralia.com/forums/Pr...&p=4903262# ). This is what jetpilot had to say on the issue: http://www.skylinesaustralia.com/forums/-t...t&p=4909159
You've done nothing wrong. If you don't have a light/low powered car they really aren't up to the task, particularly on a track with reasonably big stops like winton.
I would look at something with a higher temp rating that is more targeted towards track work. The comment about switching pads for street/track is bullshit btw. Project Mu HC+ are about the best street/track pad you will find. They aren't the nicest things on the street (they will squeel at low speed and light brake applications and they don't feel great when cold but still pull you up ok) but you will not overheat them on the track and they will last a lot of track days. As a bonus they give a lot of feed back and feel pretty good too.
I've seen comments about excessively high rotor wear but haven't seen it on stock nissan rotors (on a mates car) or on my SCR pro's. I got 8 full days out of my last set of HC+ pads with about a years street driving before that. My mate has probably done more than 8 days on his by now. Neither of us are particularly slow.
Local suppliers are currently listing lower prices than yahoo for a change. Dunno if it just hasn't been updated or they bought bulk stock during the 100Y-$ times.
http://www.project-mu.com.au/en/products/pad_hcplus.php
http://hioctaneracing.com.au/eshop/product...roducts_id=1145
I just got the QFM A1RM's and they went well at sandown. Greg was very helpful and delivery was only 2 days.
Very cheap for $130. I don't think I'll be spending big on pads again after how they performed at Sandown.
I will monitor the wear but I get to about 220kmh before jumping on the brakes and they felt similar to my DS2500's.
^^This is what I thought^^ and my car would weigh about the same as an S14.
I have RDA slotted and dimpled 310mm rotors.
Sandown has much more heavy braking than winton too. Maybe more cool down on the straights though...
Strange. Don't know what I was doing! It's on both sides of the car and all four pads so I doubt its sticky pistons.
I did a 1:41.8 and the car has 220rwkw ish.
I'll keep you updated as I go. I'll have a look to see how much mine are worn after yesterday. (My first day on them)
How did you bed them in? how many laps do you reckon?
I bed mine in over about 3 laps and then leant on them pretty hard and they were fine.
As I said in that post that Moodles quoted, the A1RM is a street pad, capable of light track work. It's not a dedicated track pad. If you want to do serious track work, step up to something like the QFM Comp 9, $179 per axle set, and is a Ferodo DS3000 equivalent pad. As apposed to the A1RM which would be a Ferodo DS2500 equivalent pad....
That's not correct. Cast iron goes through a significant structural change at 723°C. If your rotors get hotter than that, they'll be quite a different material when they cool down. In technical terms, they'll be "fscked". Google for "iron phase diagram" for more details.
It's all quite irrelevant anyway, because it's uncommon to get rotors really glowing (=around 600°), even on a track. Claims beyond that are pissing into the wind.
The thermographic paints like what DBA use on their high-series rotors are a good idea. They tell you what temperature your rotors have been, not what temperature they are now. http://www.dba.com.au/2006/techdocs/T027.asp . Note that they don't bother measuring rotor temperature over 630°; if you get that kind of rotor core temperature your discs are rooted - that's probably getting to the magic 723° in the rotor cheeks. So... what's the point of a friction material that's "rated" higher than that?
So just be weary about what benefits you're getting from a pad that claim to work far higher than any rotor will physically get. Track pads don't have sky high temp ratings, and if they do, they've simply started a pissing contest with their competitors... What track pads are is a heavier duty versions of compounds designed to withstand sustained heat. The A1RM is a great cross over pad, but if you're serious about track work, step up to something like the Comp 9.
What would define as 'serious track work' though? It's a street trimmed S14 on Semis doing no more than 3 hot laps in a session.
I might leave these on the back and look into a better pad for the front. (Off to Japan in 2 weeks so might grab some Mus while I'm there)
Hang on, lets just clarify:
Your now claiming the A1RM is a street/light track pad (with a temp rating of 0-780 degrees?) and anything with a sky high rating is just a pissing contest between manufacturers?
And that rotors shouldn't go over 723 degrees anyway? "So... what's the point of a friction material that's "rated" higher than that?" I hear you say...hmm, better re assess that 780 degree rated street pad i was considering.
You recommend these pads for just about everything yet you never give a straight answer when someone has an issue. You answer with positive spin.
I'm actually genuinely interested to know the reason for the rapid wear some people are experiencing. I'm also interested to know, in general terms, how many track days people are getting out of a set so i can determine if they actually are a bargain, or if they are buying 3 sets to every 1 of a more expensive pad.
Russman, I'm interested in your feedback
Here's some pics by the way. I left them at full resolution so you can see details easily. Assumed most people have a decent internet connection these days. :(
Front:
http://www.users.on.net/~logon/cars/progress/DSC00875.JPG
http://www.users.on.net/~logon/cars/progress/DSC00876.JPG
http://www.users.on.net/~logon/cars/progress/DSC00877.JPG
Rear:
http://www.users.on.net/~logon/cars/progress/DSC00879.JPG
Yes, and always have.
Correct. If you think a 'track' specific pad that's rated to 900-1000 degrees C, if ever going to see it, then you need to do some serious analysis to what happens to rotors LONG before that temperature... Top temp rating is not what defines whether a pad will withstand track work or not. There's a reason why rotor thermal paints never show more than 630 degrees.
No, we recommend these pads as a Ferodo DS2500 equivalent. That is, a 100% streetable pad, that will withstand light track work. And that's what they are.
If you're willing to run a pad that's less ideal for street use, that is, higher rotor wear, more noise, less cold bite etc. then there are pads above A1RM, like Comp 9 and 12 for the front, and Comp 2 and 6 for the rear. The Comp pads are $179 per axle set front or rear, or alternatively we can also supply Project Mu HC+ for $309 per front axle set. But we'll always recommend the A1RM first to people, because anything higher than that starts to become a compromise on the street.
i found they last and perform much better if you go out hard for two laps when they are new (no track day before), come in.
let em cool for as long a possible. then go out again.
there is a HUGE difference.
if you heat em up and dont let cool from new (no track day before), you get the shudder and blue around the rotor. i did this the first time
only got 3 track days. the last set did 4 i think, had another day left.
oh ive got a 33 with 324mm uas caliper adapters and standard calipers. did sd last saturday 30+ deg outside. no pad problems.
oh and the uas air deflectors and no backing plate/ dust covers.
So at least its not just me who has noticed!
Looks like the only people who see through some of the claims are those genuinely need a very high performance pad ie. not many of us. Meanwhile, the majority are ready to shoot the non believers down since they dont know any better.
I think jetpilots claims are more realistic nowadays, but plenty of questionable information has already been spread.
Personally I think temp ratings for pads are useless since there are rubbish performance pads that make big claims.. Although, would it be correct to assume the pad gets hotter than the disk? If so, then high temp ratings for pads might not be that silly if they ratings are comparable and realistic.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
