  • Replies 164
hey buddy, sorry for late reply, do have all the lines however matt might be needing them with his new engine, but will double check as i think i have a second set aswell of all the lines somewhere, will chase it up and get back to you,(Troy)
Thanks mate. Let me know.
Hey mate,
Do you the have front inner splash guards?
Mike
I'll shot gun this answer as I also wanted this! :D
He's apparently keeping it unless he's changed his mind. I'm also after this.
You got complete stock airbox (snorkel included)?
Also, RHS A-pillar trim if there aren't any holes or marks at all?
If so, how much posted to 3199 - PM if you prefer to.
Cheers
Grant
Well?
sorry everyone for slow replys working 12 hour days
- sorry my brother in law is keeping inner guards because they are in good cond, he has gtr
-do not have complete air box
-selling a pillar trims together as they have the standard tweeters in them price is in the list, would be 150 plus postage
costs, thay have very few minor scratches
Matt,
Thanks for getting back to me.
I think I'll pass on A-pillar as I'm only after RHS anyway.
Also PM me your best price on PFC HC (is it FCC3 suitable for BNR32/BCNR33)?
Cheers
Grant
I bought the brakes, and just wanted to say that Troy's an honest seller. After looking at the car, it would have been easy for someone dodgy to to dodge it up and sell it with the rust covered but he's chosen to sell the parts and be legit about it all. I'd trust this bloke y'all!
Yeah, Troy is a top bloke...wrapped everything very well and prompt communication and postage too! Awesome! I've left traders comments for you mate - please do the same for me too! THanks.
-sorry mike, wont be able to get you power window motor in time as i am going away for work for two weeks, and a mate might be taking whole door anyway.
-sorry woo hoo the drivers control module is gone also
-Darkryda someone in adelaide has put shotgun on steering wheel already if it falls through will let you know.
-front inner guards are sold already including all diffusers that are under car(godzilla4me)
-goodwin front bar (both) are sold
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
