i had this issue as well... mainly happend after i installed my stereo... i found it was because the hose was closed behind the console where the stereo is. Theres a little sensor type vent thing in the console/dash surround which looks like about 3 slits... at the back of these slits is a hose... i uncrimped this and it worked fine again... altho now it takes AGES to get cold... i think it just needs regasing.
Hey there
I just got my AC fixed 2 weeks ago, my compressor died - Compressors tend to go anywhere up to 250 for a 2nd hand one from a wrecker, but can be picked up as cheap as 150..
If you need it checked out, go to a place called "Norms Auto Air" (03) 9876 8611 @ 5/401 Maroondah Hwy Ringwood
He's a genuine bloke and will look after you, there are so many sharks out there in the Automotive AC industry!!!!!
BTW Tell him chicane with the red R33 who's compressor died sent you :cheers:
hey all just readin this thread and thought i would post a reply seens i am an air conditioner fitter and repair as well as a auto elec
well my r33 just did a compressor last week new ones i found are ex japan thats through my nissan dealer and well he said they are bout 1000 dollas delivered which isnt taht dear cos most on various aussie cars are bout 500 to 800 bucks
just for the comp
now if it is the comp you will need a regas and if want it to last as long as possible you should replace the reciever drier 'the little cylinder on the left hand side nex to the air box' as well
now i dont know how much one ( still waiting on call back)is but you should only get a new one so it all works good
if you can get hold of both of them they really arent that hard to fit just time consuming but its a good money saver for you cos the air con bloke only has to vac it down and regas it
all you need is a new orings for the hose fittings and some sealant for them or oil them up
its as easy as that
pm me if you want some ideas on what could be wrong
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
