Hi SAU Members,
I have an R33 GTST which is, for now, as stock as a rock except for the suspension and handling components.
I have been having an intermittent problem, with what I believe is fuel starvation.
The problem can be described as the spark not igniting any fuel for seconds at a time, when either backing off, or the initial moments of being hard on accelleration.
At times, when backing off to a point where you would accellerate again, the engine cuts.
I have just replaced the fuel filter, iridium plugs, oil filter, air filter and changed the engine oil to Motul Turbolight 4100.
Car was running great for two days, then the issue rose again from the dead.
I've decided not to drive the car, until I can resolve the issue.
Today, I've taken it down to TM Autosports for a fuel system evaluation.
My question is, has anyone out there ever experienced a problem identical to this, and if so, how was it resolved?
Many thanks for the help in advance.
Jim
https://www.sau.com.au/forums/topic/294915-r33-gtst-fuel-problems/
I had a similar thing for about a day... I found out the next day I was hitting boost cut at 14psi... needless to say I turned down my boost controller.
I doubt you're having the same problem though.
Having thought about it for longer now, it could be coilpack-related... check your coilpacks and/or spark plugs while you're in there. If they're still the old stock coilpacks in there, it's quite common for them to start failing. There's a DIY method of siliconing up the cracks in the edge of them to help get the spark where it's supposed to go.
Failing that, you would need new (or secondhand from wreckers) coilpacks to replace the faulty one/s.
Could also just be dud plugs.
Many thanks Mos.
Plugs were replaced with iridium units, and the coils checked out.
I'm gonna keep checking tho.
  • 5 months later...
sounds a bit like a coil pack issue, but could also be an issue with the TPS. you are opening the throttle and the tps isn't registering the movement so isn't telling the ecu to add more fuel.
Mad,
The issue is still there unfortunately.
The car has perfect Iridium plugs, which are practically new.
I will go the extent of changing the coil packs, and see what happens.
Thanks
Jim
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
