hey guys these parts will be coming off my motor ear ly next week
a set of r34 n1s with bout 9000kms on them with aftermarket split dump pipes $1700
a set of sard 550cc injectors (pink) $400
i will have pics asoon as there off
took these parts in favour of larger items
0420581496
RB26DETT use top feed low impedance, GTT use top feed high impedance pencil type injectors. RB20 use same as RB26DETT and RB25DET use sidefeed high impedance I think.
the RB26DETT is high imped, the RB20 is low imped. thats why people need to get the GTR resistor pack also when buying off GTR's.
heres some info and pics
and here the serial numbers i couldnt get in to take pics, but your more then welcome to inspect
CD0103J
1441 AA403
707160-8
and some info on n1 turbos
R34 GTR N1 TURBO SPECS:
BNR34 (N1)......Serial No. 14411-AA401 (Ball bearing centre)
BNR34 (N1)......Serial No. 14411-AA402 (Ball bearing centre)
BNR34 (N1)......Serial No. 14411-AA403 (Ball bearing centre)
C106 Compressor with a 0.60 A/R and 55T
GT25 Turbine with a 0.64 A/R and 62T
( Stock GTR R34 item specs are Serial No. 14411-AA300 Ball bearing centre but ceramic wheels 0.53 A/R and 50T and 0.48 A/R and 62T )
PN 14411-AA403 is an R34 GTR Vspec II turbo fitted from November 2000
The original R34 GTR N1 turbo has the PN 14411-AA401 (January 1999 to October 1999) and the -AA403 is listed as a direct replacement (there was also an 'in between' -AA402)
one of the dumps pipes looked like it was bashed to fit
post-16324-1257936490_thumb.jpg post-16324-1257936556_thumb.jpg post-16324-1257936620_thumb.jpg
post-16324-1257936679_thumb.jpg post-16324-1257936817_thumb.jpg post-16324-1257936839_thumb.jpg
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
