Well very excited to have had the GTR on the dyno last night for the first time since I bought it!
Big thanks to Lindo and Junior for the new turbos & countless hours of work, Jeff at Speed Lab for the tune, and Michael & Turbo Tune for letting us use their dyno til ridiculous hours!
It is now making 307kW at ALL FOURS on only 16 PSI!
Car feels great, smoother & much more responsive! It absolutely freight trains!
https://www.sau.com.au/forums/topic/295100-put-my-baby-on-the-dyno-last-night/
  • Replies 53
It's had a lot done to it mechanically -
Built Engine
Big sump
Forged Pistons
Rods
HKS 272 Cams
720cc injectors
Power FC D Jetro
Exedy Twin Plate Clutch
Oil cooler
Turbosmart E-Boost boost controller
Trial full exhaust
New turbos are Garrett -7s :)
over 300kw @ all 4 wheels with -7's @ 16psi is def a great achievement Bec.....you gotta be happy with that.
Me thinks it would be a bit of a response monster with the -7's putting out that much.
Reminds me of Andrew Blue32's car (although he's making 400kw).......he's only running 8cm journal turbos.....makes the thing come alive very early.
Sounds like yours would be very streetable
Yes it feels much more responsive now! I haven't had a proper drive yet but hopefully will tonight!
Very happy with it... Sooooo don't want to sell it now! :) Boo!
I told Jeff to keep it real safe when he tuned it, so no doubt we could have pumped more boost into it thus achieved more power, but (yeah yeah call me a girl), I didn't really see it as necessary on the street, especially these days... It'd just be asking for trouble! Hehehe. I love how the car squats when it takes off with decent pace! *sigh*
Time for a upgrade of the suspension me thinks....after i upgraded mine there is no squatting and more hauling ahead
na Damo i has 2 engines 1 in the car still runs and 1 out the car wanting to sort something out before piling money into it will be the good part of another year i need a pizza round to earn more money :) im tempted i might start eating more pizza but
awesome, i'm jealous
mate of mine has a gtst running my old 3076 making some good numbers on E85, rear shocks are totally shagged and gets amazing traction, softer is always faster in a straight line!!
I got coilover running medium to soft....but still no squatting
its all to do with spring rates Krishy, you can set a hard set of coilovers to their "softest" setting, but it will still be 10x stiffer than standard spring/shock combo.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
