  • Replies 117
Bugger the Sushi...lets just go drink some JDM beer! :/
http://www.robotsushi.com/visual.aspx
Also there is very nice Sushi place just of Toorak rd, in South Yarra. Pricey, but very nicey!
Oh and quick lesson of Asahi....
This is Asahi
Notice the 2 black Japanese symbols in the middle of the bottle.... don;'t drink this stuff! It's not brewed in Japan, usually in Oz it's from Thailand or even the UK.
This is the Asahi you want!
Notice the 1 black Japanese symbol in the middle of the bottle/can (the symbol means 'Draft')... this is the stuff you want. :)
Oh and if you want JDM Kirins, the cellar on Acland st, St Kilda and the JDM grocery market behind the KFC on Chapel st has em. In cans of 500ml goodness :)
Haha dude, try finding Japan brewed Asahi here. Near impossible. All Aus stuff is Thai brewed :)
Haha dude, try finding Japan brewed Asahi here. Near impossible. All Aus stuff is Thai brewed :(
Yep. Made in Thailand or UK.
I've only had the Japanese stuff at a place called "Teppensan" on Russell St.
I'm feeling a Sushi meet coming on, I get my new car this month. I'll organise one early December! :)
Make sure it's unofficial so I can come :D
I haven't been to an SAU meet in quite a while.
went to a nice cosy downstairs place on little burke near exhibition street the other night :)
nihonbashizen
was quite impressed.. not cheap tho! about 100$ for two well fed patrons!
Looks very pricey too.
I use to goto Yoyogi Cafe
211-213 Swanston St
Melbourne VIC 3000
Phone (03) 9663 7266
Service, food and price were all very good.
Loved Ishiya Japanese Stonegrill when I went there this year for my birthday: http://www.ishiyastonegrill.com.au/
It's on Little Bourke Street. I had the Wagyu stonegrill, myself and my partner were a little over $150 together with drinks, so not cheap, but bloody worth it.
For reasonably priced Japanese, Sapporo next to Mitcham station is fantastic: http://maps.google.com.au/maps/place?sourc...346253128765221
there was a tiny sushi shop on whitehorse rd near mitcham station, used to make up decent handrolls fresh
Well guys, I'm going to J's Surf & Turf in Brighton tomorrow night for dinner (all you can eat)!
$28 per person, and you can get half a dozen of fresh raw oysters per person :)
It seems like it's gonna be packed, I was just lucky to get a booking for tomorrow night at 8, but all the other times are pretty much booked out.
So I'll let you guys know how it goes :blush:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
