  • Replies 224
hi guys the dragon is dead but look out 4 the r 34 2 doors 1st show 4 the carand the car name is ..............................bye
My comments were deleted because they were in bad taste
i dont see why. all the mods agree and have taken stabs at the car. would be hypocritical to pin it on one person.
and im not attacking the owner either. just giving a general consensus of how people view the car, as im not the only one with those opinions. actually ive never seen anyone with a different opinion.
Edited by steveP
Not appropriate Steve .... yes snide comments may have been made, but not as blatantly as yours, and not in his thread and to his face .... that is just not nice.
You need to display more decorum, otherwise you will get a holiday. I guarantee you no mod (nor anyone else for that matter) has personally attacked someone like you just did.
Lol at clowns that think they can speak on behalf of the Mods.
Hope all goes well with the show Mal.......and please ignore idiots that post the usual dribble.
that was the whole point. im very honest and up front and not trying to make sly comment and then be all smiles to his face.
anywho point noted. ill save my comments for face to face confrontations with such monstrosities.
*shrug* while he might not have been diplomatic, he's got the right to his own opinion... Surely thats not against the forum rules.
Back on topic - should be a decent show given that we've already got 6 people keen to come, and if Mal is gracious enough to let us have a nice spot if we're early enough, I daresay I'd like to take him up on his offer
-D
-D
If you had seen the post you may not think so..... diplomatic is being used VERY loosely.
I personally would have called it Fu*#ing rude.
-D
Whats the school of thought so far here... are we gonna put up a themed display or similar to loxton styles??
Assuming I get the nod from work and the missus I would be interested also.
pretty much man, can do a different layout but still use the shadehouse/display stuff that we had last time
themes would be good, but we havent really had a chance to discuss it as a group - perhaps next SAUSA meeting we can have a thinking session and see what everyone thinks
-D
gotta have a dig even to the end don't you........and no you won't, I can guarantee it!
-D
Ben, belittling members when it's not warranted and whoring threads is against SAU rules.......you obviously didn't see what Andrew edited.
I actually got a phone call at lunch time by a member complaining about the inappropriate comments & whoring in this thread.
Probably a good thing that Andrew got to his posts before I did, cause repeat offenders get a holiday.
-D
Sounds good, due to work and being xmas I will be pretty flat chat til january now.... very few days off at all till then.
Happy to help once silly season is finished!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
