R33 Rear Bilstein / Whiteline Suspension + Hicas Lockbar + Used Exedy Clutch
By StreetWeapon · Posted
This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
