I haven't seen any pop.
In my opinion, what would most likely kill the engine is:
- Not tuned properly resulting in detonation. eg. timing not adjusted correctly, not meeting the fuel requirements, too small injectors and/or fuel pump.
- Inadequate fluid cooling, in particular on the neo's. Dori and I have both discovered how hot the oil temps run on an RB25DE+t Neo. 90 degrees after a 15minute drive to work isn't uncommon, 100degrees after driving on the motorway also not uncommon and it's not quite summer yet. A 13 row oil cooler will help in this area. I should have my kit fitted this week or next and will report back on the results.
- Too high intake temps. A good FMIC will definitely help to reduce intake temps as with 10:1 compression you want to keep things cool.
- Too much boost. Mind you I've seen the likes of WYTSKY running 15PSI through an R33 GTS4 RB25DE, but don't expect a set up like that to be long-term reliable (in my opinion anyways), it's fine if you're looking to rebuild later on. I still think that unless the engine is already in poor shape, you'll probably reach the limits of a stock factory turbo before anything else.
- The driver/owner. Like any car, if you red line it day-in-day-out, don't maintain it, don't give it time before turning off the engine, etc.. you can't expect any car to last long.
Don't skimp on a good tune, have adequate cooling where it's needed most, drive it sensibly (driving it on 7PSI on a daily and having a high boost option for 10-12 isn't going to hurt THAT much now.. ok it does hurt but you get by ok with 7PSI for just commuting to and from work), maintain and service regularly and it should be fine.
Keep in mind that there are drifter's running RB25DE+t's as well. In my opinion, if it can handle the abuse on the track, albeit combined with good cooling solutions to match, then with the above taken into consideration there shouldn't be much of an issue.
If I didn't see it that way, I wouldn't have done the conversion.
sup, top bloke.
i've got RB20de+T
been running for ummmmmmmmmmm
74+118 = ...dont know... not ven a relevant equation try again
118-74 - 44thousand klms
hasn't skipped a beat
there's no reason the engine would pop. it's a nissan, honda i can understand because they're not designed to have turbos added
nissan blocks already have the plumbing there ready to go to my knowledge, the only difference is that the compression of the head is higher. so the response is greater.
take that into consideration however. RESPONSE IS FAR GREATER.
so
do you NEED a massive front mount? no.
do you NEED 880cc injectors? no.
do you NEED a T88 with extenally gated boost gate manifold stainless gold HKS greddy frontpipe manifold turbo turbo kit? no.
in short - if you don't want your motor to go bang
then build the turbo with stock parts - once you've done that, and it works, THEN you can modify it... but my advice is don't go to nengun and ask for a extenally gated boost gate manifold stainless gold HKS greddy frontpipe manifold turbo turbo kit when you're not sure how the engine will handle having a extenally gated boost gate manifold stainless gold HKS greddy frontpipe manifold turbo turbo kit
ps
i was kidding about calling you a top bloke i just thoguht i'd throw it in there for shock value
but yeah
my advice is
do it right the first time, then build up modification parts... oh and DONT LOSE ANYTHING. TAKE NOTES OF EVERYTHING YOU DO. KEEP YOUR NUTS N BOLTS IN THE ONE PLACE. LABEL THEM IF YOU HAVE TO.
2 years and going strong! BIGGGG upgrade commencing in only a few days/week...
I'll show u Nathan, that all our blocks can take that PSI :/ that being said... I don't think ive touched red-line for atleast a month or more... maybe the secret i don't know....honestly i don't need to go over 5,000 on the street...
Can't wait for the new gear to be put in...:)
I'm waiting in anticipation to see what you've got coming! I still think your nuts :/ Any hints on what you've got in store?
You're right about that... since doing my conversion I don't feel the need to rev it out as much anymore for street driving.
I don't doubt that the DE blocks can take the pressure.. it's more a case of how reliable and for how long it can, but yours is living proof that they can take some pretty big boost without giving up the ghost.
good oil, service regularly & god damn good tune is the key.
adam, i am keen also to see whats coming next for ya you crazy bastard.
u still using the 3071?
its a little bigger then that :(
Im waiting on a single part that is being custom made by a machinist to suit
yeah ive been eyeing their motors DaGr81 and its pretty good for that price too!
i pumped thru 14.5 psi as i was testing my EBC yesterday and boy it was quick!
no traction on 18x10" work rims on 2nd and 3rd which shocked me so i backed off immediately lol
hehehehe... and this is how mine ended up staying at 15-17psi :)
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
